Anyone got an airbox for a CB500S-Y?
Netballman
Post by Netballman on Fri 29 Sep 2017, 6:00 pm
I'm looking for a replacement airbox housing for my 2001 CB500S  - suffering from the old air filter cover rotating bolt problem Sad so only interested if they haven's stripped yet!
And, just on the offchance... also a main spring for the centre stand (which apparently are not made any more...
Cheers chaps Smile
Re: Anyone got an airbox for a CB500S-Y?
Post by Jameshambleton on Fri 29 Sep 2017, 6:58 pm
I think I've got an airbox at home, I'll have a look on Sunday when I'm back at home
Fair Weather Rider
Fair Weather Rider
Post by Fair Weather Rider on Fri 29 Sep 2017, 7:00 pm
If James hasn't got one I think I have.
I will check tomorrow.
l.t.racing
l.t.racing
Post by l.t.racing on Fri 29 Sep 2017, 10:27 pm
I may have the spring, i binned a stand few days ago from a cb, at work, will check monday
Netballman
Post by Netballman on Sat 30 Sep 2017, 10:14 am
Wow guys, excellent! It's been a long time since I've been around the forum and it's great to see it is still as helpful and collegiate as ever Smile
I shall wait to hear from y'all!
ZekeVal
ZekeVal
Post by ZekeVal on Sat 30 Sep 2017, 11:39 am
In last resort, or if you don't feel like throwing the old airbox, it's somewhat easily repairable:
- Apply heat with the tip of a soldering iron to the seized screw until it softens the surrounding plastic (a few minutes will do).
- Then use pliers or vise grips to pull the nut-insert assembly out.
- Unscrew the insert, clean the thread and glue it back in the airbox.
- Apply grease to prevent further corrosion with the screw and voilà Wink
Fair Weather Rider
Fair Weather Rider
Post by Fair Weather Rider on Sat 30 Sep 2017, 12:25 pm
@Netballman wrote:I'm looking for a replacement airbox housing for my 2001 CB500S  - suffering from the old air filter cover rotating bolt problem Sad so only interested if they haven's stripped yet!
Cheers chaps Smile
Sorry no airbox, have checked shed, must have slung it.
Zekeval's idea looks as if it will sort you.
Post by eternally_troubled on Sun 01 Oct 2017, 5:44 pm
@Netballman wrote:Wow guys, excellent! It's been a long time since I've been around the forum and it's great to see it is still as helpful and collegiate as ever :)
It doesn't change much 'round 'ere :)
Sadly (for you) I don't have either an airbox or a centre stand spring...
Post by Jameshambleton on Mon 02 Oct 2017, 6:23 pm
Yup I've got one, currently missing the cover where the air filter goes and the bolts but I'm sure it's somewhere in the shed, if not you've already got them on your airbox.
Say £15 posted?
I might also have the main stand spring(s) too, can you measure them up and I'll have a look. I'm sure I've got some in draw somewhere!
    Current date/time is Sat 23 Feb 2019, 3:16 am
