Faulty neutral switch
Post by wornsprokets on Sun 17 Sep 2017, 7:39 pm
As cb 500s i have was left up for years going through some of previous owner bodges....the neutral switch doesnt work... so i disconnected wire at the switch and bridged wire to earth...and neutral light comes on so faulty neutral switch....(1) so do i have to drain oil out to replace the switch.....(2) the side stand switch is by passed too... i dont think i fix this... if i have functioning neutral light...but both not working is dodgy....
Fair Weather Rider
Fair Weather Rider
Re: Faulty neutral switch
Post by Fair Weather Rider on Mon 18 Sep 2017, 9:57 am
In would rather have a side stand switch, than a neutral switch, if I had to make a choice.
Personal choice.
Post by Jameshambleton on Mon 18 Sep 2017, 11:04 am
I'd personally (and have) would rather have a neutral indicator than the sidestand light. By not having the sidestand light you're more aware of the sidestand and it's easy enough to check just by moving your leg out, it becomes like muscle memory or the typical routine of all the bike gear on and now need a wee  Laughing
louis_sutton
louis_sutton
Post by louis_sutton on Mon 18 Sep 2017, 3:40 pm
Mine was failing when the engine was hot. Pretty easy to remove, did it with a cold engine and lost no oil. It needs a crush washer if I remember correctly (and it does mean digging through the dirt from the chain). Just screws out.
Post by wornsprokets on Mon 18 Sep 2017, 5:51 pm
Thanks for the advice louis, good to know i dont have to drop the oil....as i just changed it...
    Current date/time is Sat 23 Feb 2019, 3:07 am
