Size of Vaccum Hose
MegaChops
MegaChops
Size of Vaccum Hose Empty Size of Vaccum Hose
Post by MegaChops on Fri 08 Sep 2017, 11:52 am
Hi All,
New to the forum but I've been doing up a CB500 project for the last 6 months and shes nearly ready for the MOT. I just need a bit of help with the last couple of bits,
The Vacuum hose (the clear tube from the tank to the left side of the carb) does anyone know the diameter the tube needs to be?
I need to change the brake fluid but the front master cylinder screws dont want to come out(back brake is drum), any tips or suggestions to help with this?
Thanks in advance.
Mike
Size of Vaccum Hose Empty Re: Size of Vaccum Hose
Post by Jameshambleton on Fri 08 Sep 2017, 5:33 pm
About mid way down, contains other info you may find useful
http://www.cb500club.net/t225-specs-stats#44642
MegaChops
MegaChops
Post by MegaChops on Fri 08 Sep 2017, 6:44 pm
Very useful, thanks dude.
Post by eternally_troubled on Tue 12 Sep 2017, 10:46 pm
Plus (in case you don't know) the original tube isn't clear - it's black.  I suspect that if it is clear then it may have been replaced with car window washer/sprayer hose (IME it is a similar diameter) - this will work for a bit but isn't a good idea as it will degrade faster than 'real' petrol-proof hose.
    Current date/time is Mon 23 Sep 2019, 7:03 pm
