New tires
cebecero
cebecero
New tires
Post by cebecero on Mon 07 Aug 2017, 6:47 pm
I know they are many post about that, but if is useful for someone my experience, i´m happy.
I change my front and rear tires (when i buy my bike, mounts a Pirelli Sport Demon) and decided to put a front 120/70/17 and a 140/70/17 rear. Front Metzeler z6 and rear Bridgestone BT 45.
I put a Metzeler front tire because i read the BT 45 are a bit hard, and in Galicia (my region) many times the weather is cold and rainy and i read good opinions about that tires.
To the rear tire i put the BT 45 because is not a problem (for me) if is harder, i think is most durable.
I make a travel in Portugal with this new tires. 5 days, with bagage and a tent, mountain roads, more or less 1000 Km in total. The conclusion:  i´m very very very happy with the change.
Is true, the bike now is a little bit slower to change direction, but is most stable and comfortable. I find the bike more "on the road" and is a little bit more slower (for me is a good thing because i´m only 1,75 meters tall).
I recommend the tire width change?? Yes, absoluty
I recommend the Metzeler z6?? Yes, absoluty (is a shame not produce a rear 14/70/17)
Hope this is useful for someone Smile
Un saludo!!
Re: New tires
Post by ANDYC on Mon 07 Aug 2017, 7:29 pm
The Z6 is a radial tyre and won't work properly on the standard wheel as it's not wide enough.
cebecero
cebecero
Re: New tires
Post by cebecero on Wed 09 Aug 2017, 6:35 pm
Hi Andyc,
i don´t see this reply first.
When i came to my mechanist to put on the new tires i ask to him, if this radial fix on my CB, and says "no problem".
I ride more or less 1.000 Km with that, and like i said, i feel really well, and looks well to.
What can happen with this tyre? is dangerous? is posible to "go out" of the rim?
Thanks a lot
Re: New tires
Post by ANDYC on Wed 09 Aug 2017, 7:00 pm
If you check with Metzeler for the rim size needed to suit the radial tyre they will probably tell you that it needs to be a 3.5 rim.
cebecero
cebecero
Re: New tires
Post by cebecero on Wed 09 Aug 2017, 7:07 pm
I search in the manual this sizes, but i don´t found it.
Did you know the rear and front rim measures??
Thanks!!
Re: New tires
Post by ANDYC on Wed 09 Aug 2017, 7:34 pm
The front is 2.50 and the rear is 3.50.
cebecero
cebecero
Re: New tires
Post by cebecero on Wed 09 Aug 2017, 7:36 pm
Muchas gracias, ANDYC Smile
Re: New tires
Post by ANDYC on Wed 09 Aug 2017, 7:47 pm
You're welcome Juan.
Hcb
Hcb
Re: New tires
Post by Hcb on Thu 21 Sep 2017, 1:10 pm
Hi.
Now, I use Bridgestone tires.. 140-80-17 back, and 110-80-17 front.. BT45 both.
Very good tires, and are wider than the original ones.
Very beautiful if you see the motorbike from back.
Busby
Busby
Re: New tires
Post by Busby on Sun 01 Oct 2017, 7:55 am
@cebecero wrote:Muchas gracias, ANDYC Smile
Hi Juan, Just seen your original post re tyre widths How would this change affect the ITV inspection? As here in Mallorca they are very serious about the specification meeting standard production specs?
Regards B.
Hcb
Hcb
Re: New tires
Post by Hcb on Sun 01 Oct 2017, 10:09 am
Regards B.
In Sevilla, Spain, having 140/80/17 back and 110/80/17 front, no problem with the ITV in .. two inspections! I think that you can put this tyres without problem.
burudi
burudi
Re: New tires
Post by burudi on Fri 05 Oct 2018, 7:53 pm
hey carballeira!
Re: New tires
    Current date/time is Sat 16 Feb 2019, 2:50 am
