Choke won't stay on, keeps spring back
Arfa
Arfa
Choke won't stay on, keeps spring back Empty Choke won't stay on, keeps spring back
Post by Arfa on Tue 25 Jul 2017, 9:08 am
Got a CBF500, but I assume the choke part will be common to the CB500. When I pull the choke knob out to warm engine, it keeps springing back. Bit of a pain to have to keep holding it out whilst it warms up. There's definitely some damage to the cable mount by the knob which the prior owner has secured with a cable tie. Dunno if this is the problem, or if it's something else. Be good to know for sure before I order a new choke cable (easy to fit?)
Fair Weather Rider
Fair Weather Rider
Choke won't stay on, keeps spring back Empty Re: Choke won't stay on, keeps spring back
Post by Fair Weather Rider on Tue 25 Jul 2017, 9:29 am
Shouldn't need choke this weather.
                 Very Happy
Arfa
Arfa
Post by Arfa on Tue 25 Jul 2017, 9:37 am
Still seems to need a bit. Revs just cover around 800-900rpm and it keeps threatening to cut out, and often does after a little while. Once it's warmed up for 2-3 minutes, it's fine and it nicely idles around 1400rpm odd, so I'm reticent to tweak the idle speed up.
Post by ANDYC on Tue 25 Jul 2017, 12:44 pm
Try tightening the plastic nut holding the choke cable to the cylinder head bracket, I believe it relies on friction to hold the choke plungers in position.
Post by trevor machine on Sat 29 Jul 2017, 5:18 pm
@Arfa wrote: Once it's warmed up for 2-3 minutes, it's fine and it nicely idles around 1400rpm odd, so I'm reticent to tweak the idle speed up.
Fwiw, I'd almost be tempted to tweak it *down* - iirc book is 1250rpm @ idle.
    Current date/time is Sun 22 Sep 2019, 1:01 pm
