Can any Hel brake line users answer this?
Can any Hel brake line users answer this? Empty Can any Hel brake line users answer this?
Post by liverpool_f_ on Tue 20 Jun 2017, 7:14 pm
Hi all,
Like many, I have upgraded my front brake hose to a steel braided Hel. I have always felt my front brake required a lot of force on the lever to get max stopping power. I know its only single disc and I have never ridden another CB500 to compare but it does feel overly firm.
My question is how many cooper crush washers have others used when installing these hoses? I installed 1 washer, then the banjo union, then another washer and finally the banjo bolt. It has occurred to me recently that if I used the incorrect number (i.e. 2 instead of 1), then the hole in the bolt won't line up correctly with the gallery in the banjo union. If its offset a bit and only part of the hole is protruding into the union, then it will restrict fluid flow and result in an overly firm brake lever.
I don't want to take it apart and measure because that will result in needing to bleed the brakes. Any wisdom is much appreciated.
Can any Hel brake line users answer this? Empty Re: Can any Hel brake line users answer this?
Post by Jameshambleton on Tue 20 Jun 2017, 7:55 pm
masterclyinder/caliper, Washer, braided hose, washer, banjobolt.
Vardypeeps
Vardypeeps
Post by Vardypeeps on Wed 21 Jun 2017, 1:18 pm
Same here when I fitted my front Hel hose Smile
Loads of power in my front brake but it needs the new pin a bought fitting and the pistons need a little spruce so they retract better.
Check all of the caliper mount and the slider it sits on, clean and re-grease this whilst removing corrosion and it might help?
Other than that, try to bleed the top banjo bolt at the master cylinder as I found a lot of air gathered there after a short ride.
Post by liverpool_f_ on Sun 25 Jun 2017, 10:33 pm
cheers gents. The front calliper has been serviced and the master cylinder rebuilt so maybe I am just expecting too much from a single disk setup.
    Current date/time is Wed 21 Aug 2019, 7:39 pm
