Coil voltage
Cally4x4
Cally4x4
Hyper Viper
Hyper Viper
Coil voltage  Empty Coil voltage
Post by Cally4x4 on Mon 05 Jun 2017, 4:48 pm
Hi like the topic name I'm looking for the voltage the ignition coils should get and also should they have a constant voltage or should it go up and down
Cheers for any and all help
Coil voltage  Empty Re: Coil voltage
Post by eternally_troubled on Fri 23 Jun 2017, 8:01 pm
Firstly I'm assuming you are talking about the low voltage side of the coil Smile
It will be going up and down but at the same rate as the sparks, so you won't see it a multimeter. You'll only really be able to see it with an oscilloscope.
What were you trying to diagnose?
    Current date/time is Wed 21 Aug 2019, 7:33 pm
