Spark issues - not a cb500
Spark issues - not a cb500 Empty Spark issues - not a cb500
Post by Jameshambleton on Wed 03 May 2017, 8:59 pm
So I've acquired a gpz500 as a none runner from a friend previously stolen recovered 4 times!  Shocked
I've tried to start it and found it hasn't got any sparks from either coil.
I've fully charged and tried 2 different batteries, cleaned the spade connections on the coils and checked the connections from the pickup going into the loom.
I've tried a different set of coils from my cb400sf and I'm getting the same result, and I have tried grounding the spark plug to a clean bit of metal on the engine with no avail from either the cb400 or the gpz coils. suggestions?
I've ran a multimeter inline with one coil and it was reading 5v but now the leads on my cheapo multimeter have had it so I can't test anything else oh and the fuses are ok
Suggestions?
Spark issues - not a cb500 Empty Re: Spark issues - not a cb500
Post by ANDYC on Thu 04 May 2017, 8:33 am
It may be the ignition pick up coil. The one that reads the timing from the trigger wheel on the crankshaft.  Or possibly the CDI unit.
Pukka
Post by Pukka on Thu 04 May 2017, 2:30 pm
@ANDYC wrote:It may be the ignition pick up coil. The one that reads the timing from the trigger wheel on the crankshaft.  Or possibly the CDI unit.
What year model it it? I believe the pre 1994 models had an issue with the alternator magnets which could take out the ignition pickup coils if they went as above.
Post by Jameshambleton on Thu 04 May 2017, 3:45 pm
Mine's the 94 model so it shouldn't suffer from that issue. It's the mk2 so it shouldn't be affected as it was the mk1 that suffered from that issue afaik.
I'm waiting on some new leads for my multimeter and then I'll try again. I rechecked the fuses today and they were all intact.
Post by eternally_troubled on Sun 07 May 2017, 7:48 pm
When the multimeter bits come I'd certainly test that there is some kind of continuity to the ignition pick-up coil - if you are luky then the Haynes (or whatever) might list a nominal resistance (suffice to say it should be less than infinte!).
Also - you could try (v briefly!) connecting 12V (probably better with 6V) across the coil then removing it - should cause a spark across the spark when you remove the supply.
Post by Beresford on Sun 07 May 2017, 8:54 pm
On Gumtree there's a stolen recovered 2003 GPZ500S for sale near me, less than 20K miles. Asking £300 or offers. Would that be worth a look. No doubt it needs work, at least a new lock barrel and key.
Post by Jameshambleton on Mon 08 May 2017, 5:59 pm
Ok so I've found the issue, on the ignition barrel there is a 500 ohms resistor. When this is powered the signal goes to the cdi that controls the coils. When the bike is hot wired the resistor isn't present so the bike won't start as the cdi isn't telling the coils to fire the spark.
Now my option is a new ignition as this one is also after market so the socket wiring points are in different locations, so I can't solder on the connections as I had hoped.
Spark issues - not a cb500 Y4mrWx1DA6pswQ-WGd8WO2EHPW5gWRrA_Y_DP_HQ9nj8-s8HsGMgb9r-o-JN30MOD9I8HMYymRvzhip_lht1PzhETm0nGJJQh01xpkjoonRWpra45yL6s1DeX8jEBXLpmMU6PmhdCC4cJI49uFJJxK0jUVtbJ0zxJngWlXxmHpjMaw_IAAtGtmcCGQC_Tnz7GUJPQoYEsFWGCBZdknTVvY-oQ?width=4128&height=3096&cropmode=none
Post by eternally_troubled on Wed 10 May 2017, 9:26 pm
@Jameshambleton wrote:Ok so I've found the issue, on the ignition barrel there is a 500 ohms resistor. When this is powered the signal goes to the cdi that controls the coils. When the bike is hot wired the resistor isn't present so the bike won't start as the cdi isn't telling the coils to fire the spark.
Is that, by any chance, an anti-hotwiring resistor? :) You could always move the resistor into the loom and use a different type of lock/switch...
    Current date/time is Mon 16 Sep 2019, 10:06 pm
