coolant choice
ar1
coolant choice
Post by ar1 on Mon 01 May 2017, 2:26 pm
I am not sure i have used the right coolant is the pink stuff ok
Fair Weather Rider
Re: coolant choice
Post by Fair Weather Rider on Mon 01 May 2017, 2:57 pm
It should be the Expensive stuff that doesn't Knacker your water pump seal.
I think it is Silicate free. Mines green.
Somebody on here will know for sure.
Re: coolant choice
Post by Jameshambleton on Mon 01 May 2017, 3:05 pm
I chuck in this stuff after roughly diluting it 50/50.
I personally use tap water but I can get away with it in my area as I've got soft water so there isn't any lime in it. Best way to tell what sort of water you've got is by looking inside your kettle, if it's old like mine 5+ years and there isn't any limescale
http://www.halfords.com/motoring/engine-oils-fluids/antifreeze/halfords-oat-antifreeze-concentrate-5-litres
ar1
coolant choice
Post by ar1 on Mon 01 May 2017, 3:41 pm
I have used the ready diluted pink coolant from halfords will this be ok for the pump seal ? i have never change the coolant before regards J
Re: coolant choice
Post by Jameshambleton on Mon 01 May 2017, 3:45 pm
@ar1 wrote:I have used the ready diluted pink coolant from halfords will this be ok for the pump seal ? i have never change the coolant before regards J
prediluted own brand is Silicate free
ar1
Re: coolant choice
Post by ar1 on Mon 01 May 2017, 3:55 pm
Cheers ok then, safe riding
Re: coolant choice
    Current date/time is Thu 16 Aug 2018, 8:44 am
