Throttle cable awareness week
Throttle cable awareness week  Empty Throttle cable awareness week
Post by Jameshambleton on Sun 30 Apr 2017, 7:19 pm
Since we have a clutch cable awareness week I thought it would be rather fitting to have a throttle cable awareness week too.
For uhh reasons.
Throttle cable awareness week  Y4mfBnvzAYuuQcskLb49OZJYTrbCaimvBuFzFE8IjiUOBczpp6xsVo7Jg4OlTpMxaemEYZDqn-NMS_by2KC86sivMzWzyw6myYbIjoeyxb929-LLDMY4Sy0esbFJGh6luLX1k2lqBMaAmbcimC1bZ9CVXQxFcFdFdx3T3ziW6-DZkCu4B7rNG6p1kVgPZuiRs2ikNZOtCZO_OfgKA_mdW_7Gg?width=4096&height=3072&cropmode=none
The push cable can be used as a pull cable but you CAN NOT ride with just a push cable and no pull as previously thought.
Throttle cable awareness week  Empty Re: Throttle cable awareness week
Post by trevor machine on Sun 30 Apr 2017, 8:30 pm
James you said clutch when you meant throttle! Wink
Post by Jameshambleton on Sun 30 Apr 2017, 8:35 pm
@trevor machine wrote:James you said clutch when you meant throttle! Wink
Cheers, it's been a long day and I had just finished work at the time.
Post by trevor machine on Sun 30 Apr 2017, 8:40 pm
Bit knackered me self tbh. Probably done about four hundred miles the last 2-3 days - holy shite it was windy today down Fimber way and over at Scarborough. And could too, truth be told. Too cold for May!!
Post by sullivj on Sun 30 Apr 2017, 9:44 pm
That looks like a massive roadside ball ache James.
Post by wornsprokets on Sun 30 Apr 2017, 10:30 pm
Our cb's are getting old maybe be good idea to change throttle cables as matter of course ....better than  road side break down....
Post by Jameshambleton on Sun 30 Apr 2017, 10:54 pm
I completely forgot to add that the cable snapped part way along the length and not at either end.
Post by teamster1975 on Mon 01 May 2017, 1:22 pm
What a pain James, but well done for the road side Macgyver fix Smile
Post by stormbringer on Mon 01 May 2017, 5:16 pm
@Jameshambleton wrote:I completely forgot to add that the cable snapped part way along the length and not at either end.
Say what?!?!?
Which brings me to ask this question:
Any up-front signs this was going to happen? Stiff operation, a sense of something catching, anything?
And: With a Throttle Cable Awareness Week, we should have a name to go with it, shouldn't we?
  • National Clutch cable awareness week - Nuckuckaw - primo August
  • (Global?) Throttle cable awareness week - NoNameSoFar - primo May
  • International Headlight awareness week - Intheaw? - primo April
Post by trevor machine on Mon 01 May 2017, 5:57 pm
Chain Slider Remembrance Sunday
Post by Jameshambleton on Mon 01 May 2017, 6:41 pm
Say what?!?!?
No sign of anything out of the norm to suspect anything.
Cable was lubricated all the way from the switch gear down to the carbs.
I've been rather aggressive with the throttle the last two days so that won't have helped, had it on the back wheel more times than I care to remember. funny enough, I was actually taking it steady as I was on my way home going in the opposite direction to what I'm use to, slight incline and then put the power on to maintain my speed and it just went there and then.
Post by stormbringer on Mon 01 May 2017, 6:57 pm
@trevor machine wrote:Chain Slider Remembrance Sunday
Haha. But with chain sliders lasting so much longer than cables, wouldn't that be a decade-thing.
1998-2008-2018-2028?
2018: The Year Of the Chain Slider? The chinese can keep their snakes, dragons etc...
Post by trevor machine on Mon 01 May 2017, 8:43 pm
lol
Post by Jameshambleton on Mon 01 May 2017, 10:29 pm
@sullivj wrote:That looks like a massive roadside ball ache James.
Wasn't too bad actually, philips screwdriver and a 5 and a 4mm allen key and all was sorted to sort it out..
Throttle cable awareness week  Y4m0V5GT0kOcl9x1to5aTV_rxDKIYKMmN8t1t0bDDxpBtOB9WhhvvdNJW0i0aewLmRIm0Sbt1qK5ya51KDDQpmX3MU3Pd5wyJsUZEiFAHfxphuVyHHsfFLMiJTEAEiLJMULCbfDw5oXolZdq_9PdfORzgMFiW8BVijwN4fJI4qk3U36UU8HtESlL2mCaeZkrtD1oDqjVfpI178ttPUCymX6oA?width=3096&height=4128&cropmode=none
Throttle cable awareness week  Y4mGw4qONWZitF8lSJ0yjgCVJFj9lXNBAYaXlb3E4Ny91qnmfSKT0Ae2LO9Mb3iuujLD3TzReNuVWx2wz4taw34cBwTd9AEz08wFUQhglNWapOXNNYndfU5znKAjKlFdT_qOuqLU25lIhskKx2KMhKSiGS-uq-kzLZDpyMH_K26RSr6Oq48UiUjZgFh1MzN5-rbWPhphEdWh9IXjVolnojBAg?width=3096&height=4128&cropmode=none
Post by eternally_troubled on Wed 03 May 2017, 6:54 pm
Mine snapped in just this way too - sadly I didn't have any tools on my bike (at the time) and had to blag a lift!
I'd certainly suggest that we had a throttle cable awareness week (T-CAW?) - mine seemed to have failed due to age (the outside had failed and let water in which corroded the inside cable) rather than wear.
skyerae
skyerae
Post by skyerae on Thu 04 May 2017, 6:33 am
I had my bike sat up for over a year and when getting it sorted for the MOT the throttle wouldn't snap back to rest position when released. Took cables off (and carburettors) and lubed them with oil (using a pressurised cable oiler) and checked the spring on the carbs which was fine. Replaced all and same issue. Came to the conclusion that the inner cable was frayed. Ordered new Honda cables and fitted using original route for cables and still sticking. Took off and routed cables as straight as possible and problem solved. Fitted everything and passed MOT a few days later. For the price of new Honda cables I felt it was worth the investment - the bike is 23 years old after all  Shocked
    Current date/time is Mon 16 Sep 2019, 9:38 pm
