Clutch oil seal
paul1098
Clutch oil seal
Post by paul1098 on Sun 23 Apr 2017, 12:47 am
Anyone managed to change the oil seal on clutch operating rod from the outside?
I was hoping to do it as a quick fix to a very slight weep rather than pulling clutch cover off.
Re: Clutch oil seal
Post by ANDYC on Sun 23 Apr 2017, 12:57 pm
No it can't be done from the outside.
Sorry to be the bearer of bad news but to remove the operating arm/rod the plunger and spring needs to be disconnected from the inside.
It's not a difficult job though, keep the bike on the sidestand to minimize oil loss. The gasket may need replacing depending on your luck.
paul1098
Re: Clutch oil seal
Post by paul1098 on Sun 23 Apr 2017, 3:38 pm
I was hoping I could do it without removing the rod by creating a seal puller with 3 screws.
Think I'll get myself a gasket just in case as I'm not overly lucky.
Re: Clutch oil seal
Post by ANDYC on Sun 23 Apr 2017, 4:02 pm
The flaw with your plan is that the arm is welded to the shaft so the seal wouldn't pass over it.
Having a gasket handy is the approach that I take. You may not need one but it would sure be better to have a spare gasket than not have one.
paul1098
Re: Clutch oil seal
Post by paul1098 on Sun 23 Apr 2017, 5:59 pm
That would be a slight flaw.
I've got a case protector on so can't see top of arm & I just assumed it would be bolted.
Re: Clutch oil seal
Post by ANDYC on Sun 23 Apr 2017, 6:12 pm
In which case that will have to come off to allow the shaft to be removed.
paul1098
Re: Clutch oil seal
Post by paul1098 on Sun 23 Apr 2017, 11:32 pm
I'll just cut the top of it off as not sure how easy it'll be to get it off as it's fixed with silicone.
Re: Clutch oil seal
    Current date/time is Tue 22 Jan 2019, 4:18 am
