loads of parts
loads of parts
Post by Jameshambleton on Sat 22 Apr 2017, 10:46 pm
I've got access to a load of parts that a friend of mine is selling, though I only get the opportunity once every 2 weeks.
There is boxes and boxes of stuff including original shocks, indicators, clocks, rear cowls, flasher relay, footpeg hangers and loads more.
If there is any parts that anyone is interested in any parts comment below and I'll see what I can do.
Parts to ask for so far:
rear shocks
Low milage naked clocks
Seat lock
Naked headlight
Set of original indicators
Swingarm chain protector
Naked clocks
Seat in good condition
cooling fan
Red R model rear cowl NO CRACKS, Rentec rack - Lammydave
x2 brembo mastercylinders - me and Wornsprockets
Rear indicators -  stelladragon
Last edited by Jameshambleton on Tue 23 May 2017, 8:57 am; edited 17 times in total
Llewelyn1965
Llewelyn1965
Re: loads of parts
Post by Llewelyn1965 on Sat 22 Apr 2017, 11:48 pm
James, I'm after a pair of fork stanchions if he has any. I need straight ones with no pitting, but would take some straight ones that need re-chroming at a push.
Re: loads of parts
Post by stormbringer on Sat 22 Apr 2017, 11:51 pm
Any seats around? I've tried to get hold of one, but have to far had no luck. I'm intending a 'seat-rebuild', meaning my only requirement is the seat pan is not broken.
Re: loads of parts
Post by Jameshambleton on Sun 23 Apr 2017, 5:40 am
@stormbringer wrote:Any seats around? I've tried to get hold ofny one, but have to far had no luck. I'm intending a 'seat-rebuild', meaning my only requirement is the seat pan is not broken.
4 seats 3 are in good condition and 1 has tear in it
Re: loads of parts
Post by Jameshambleton on Sun 23 Apr 2017, 5:46 am
@Llewelyn1965 wrote:James, I'm after a pair of fork stanchions if he has any. I need straight ones with no pitting, but would take some straight ones that need re-chroming at a push.
The for the cost of chroming you can buy a new stanchion for  £120 on wemoto. I know he sold a pair of forks  for £140 other week.
Re: loads of parts
Post by stormbringer on Sun 23 Apr 2017, 6:59 am
@Jameshambleton wrote:4 seats 3 are in good condition and 1 has tear in it
Sending you PM. Hoping for this to go through - next month. Finances at the moment are low.
Fair Weather Rider
Fair Weather Rider
Re: loads of parts
Post by Fair Weather Rider on Sun 23 Apr 2017, 9:19 am
I am after a par of rear shocks.
Re: loads of parts
Post by Jameshambleton on Sun 23 Apr 2017, 5:55 pm
@Fair Weather Rider wrote:I am after a par of rear shocks.
Can do that for you, I'll make a list of all the parts that I need and I'll get back to you with some prices within the next 2 weeks.
hh_12345
hh_12345
Re: loads of parts
Post by hh_12345 on Sun 23 Apr 2017, 8:10 pm
I am looking for a set of original indicators.
Re: loads of parts
Post by Jameshambleton on Sun 23 Apr 2017, 8:26 pm
@hh_12345 wrote:I am looking for a set of original indicators.
Added to the list!
hh_12345
hh_12345
Re: loads of parts
Post by hh_12345 on Sun 23 Apr 2017, 9:33 pm
Thanks!
skyerae
skyerae
Re: loads of parts
Post by skyerae on Mon 24 Apr 2017, 6:24 am
Looking for a good seat, naked clocks (if available) and a drive chain slider (this fits under the chain and protects the swing arm from any damage from the chain). Let me know, cheers.
Fair Weather Rider
Fair Weather Rider
Re: loads of parts
Post by Fair Weather Rider on Mon 24 Apr 2017, 9:14 am
Thank you.
Re: loads of parts
Post by Jameshambleton on Mon 24 Apr 2017, 9:21 am
@skyerae wrote:Looking for a good seat, naked clocks (if available) and a drive chain slider (this fits under the chain and protects the swing arm from any damage from the chain). Let me know, cheers.
Any preferable milage for the clocks and I'll try to get some the closest to what you want.
I doubt there will be a chain slider but I'll try and ask.
skyerae
skyerae
Re: loads of parts
Post by skyerae on Mon 24 Apr 2017, 5:43 pm
The mileage on my clocks is 30801 but this increases by about 250 miles a week due to travelling to work. Don't mind if it is a bit more - it is the white casing around the back of the instruments that is cracked, most likely dropped by a previous owner. There is damage to both sides of the engine, the gearbox cover and alternator cover.
Re: loads of parts
Post by Jameshambleton on Mon 24 Apr 2017, 7:47 pm
@skyerae wrote:The mileage on my clocks is 30801 but this increases by about 250 miles a week due to travelling to work. Don't mind if it is a bit more - it is the white casing around the back of the instruments that is cracked, most likely dropped by a previous owner. There is damage to both sides of the engine, the gearbox cover and alternator cover.
I'll have a look in my box of bits and I'll see if I have one going spare rather than the whole clock assembly
skyerae
skyerae
Re: loads of parts
Post by skyerae on Mon 24 Apr 2017, 8:13 pm
That would be ace, can they be removed from the clocks easily? I haven't really looked yet as I seem to spend a lot of time fixing minor niggles on the CB - just replaced both the water pump o-rings as it was leaking. Although the o-ring seemed to be lost in the seal groove (the groove is huge, you could fit three o-rings in there) it has stopped the leak, with no sealant used at all. Then cleaned the bike which lead to it snowing today Smile
Re: loads of parts
Post by Jameshambleton on Tue 02 May 2017, 9:26 pm
Any other bits? Before I contact my mate as I'm picking up the stuff on Saturday night
Re: loads of parts
Post by Jameshambleton on Sun 07 May 2017, 7:54 am
apparently there is someone selling new fork stanchions for £140 if you want me to get some details for you?
Llewelyn1965
Llewelyn1965
Re: loads of parts
Post by Llewelyn1965 on Sun 07 May 2017, 8:47 pm
Is that for a pair? I've seen a few new ones for £110 each
Re: loads of parts
Post by Jameshambleton on Sun 07 May 2017, 9:38 pm
@Llewelyn1965 wrote:Is that for a pair? I've seen a few new ones for £110 each
I believe so, I'll try and find out the details and pm you them.
Llewelyn1965
Llewelyn1965
Re: loads of parts
Post by Llewelyn1965 on Sun 07 May 2017, 11:01 pm
Ta
Lammydave
Lammydave
Re: loads of parts
Post by Lammydave on Mon 08 May 2017, 4:55 am
hi,
looking for a rear cowl for an r ... mine is red, but would consider any as long as no splits
thanks
Re: loads of parts
Post by Jameshambleton on Mon 08 May 2017, 10:56 am
@Lammydave wrote:hi,
thanks
I've got a black one but it's scuffed. I know my friend has a red one with your colour of decals. I'll check next time I'm there (20th)
Lammydave
Lammydave
Re: loads of parts
Post by Lammydave on Tue 09 May 2017, 5:26 am
thanks
thank you
Re: loads of parts
    Current date/time is Sat 16 Feb 2019, 2:49 am
