enginecompatability
berno2020
enginecompatability
Post by berno2020 on Mon 17 Apr 2017, 1:46 pm
Hi I'm new to the club I have a crashed cb 500 v and I'mwondering  Iis the engine a straight swop with the cbf range as well? Or any other parts that can be sstopped between the 2 bikes
Re: enginecompatability
Post by ANDYC on Mon 17 Apr 2017, 2:04 pm
The cylinder head is different although it can be used if you blank off the air passages. The CB head is a straight fit. The speedometer pick up is from the top of the gearbox as it has electronic clocks. The CB airbox fouls the sensor so it would need to be blanked off. The gearbox output shaft is 5mm longer which positions the sprocket out by 5mm.
And welcome by the way.
    Current date/time is Mon 28 May 2018, 2:17 am
