Street fighter notes
Street fighter notes Empty Street fighter notes
Post by Jameshambleton on Wed 12 Apr 2017, 10:05 pm
Dumping my notes here as I can't think of anywhere to save them. Any suggestions will be welcomed though.
Street fighter notes Y4mHB-unONu2wsf-LrwsMsnQl02aizYnC0iJcaGqGUqUhZ9ZqTGQuCnSXbunjbibxFIPWSL_-98LDZp5HU9rf0-aJg8VKZevDJR2nJRt8cqNmiVAkEDSqYHdOQp4SuQclEyz06nf_qVBLj-BxSd0IURiN_fqBx-gZhKMbjhD7kmJO-4Q9heM9xPj5B-nl-XLYSzXlFc1EY-KSS-iiz0k9hs0Q?width=1026&height=645&cropmode=none
Upside down front end
http://www.allballsracing.com/index.php/forkconversion
stem length to lower bearing shield 245mm
Triumph Speed Triple Front wheel  pirat
Tiger 1050 nissin calipers
Front end dimensions
Triumph Tiger 1050 caliper offset from the mounting bolt to central disc location 21mm
Speed triple 1050 se Disc diameter 320mm
Speed triple 1050 se wheel spacers 29.5mm
Speed triple 1050 se disc - disc outer distance 134mm
Speed triple 1050 se hub (bearing to bearing) 107mm
Speed triple 1050 se wheel with spacers 165mm
5mm disc thickness
disc to current caliper mounting holes 26mm
9.5mm spacers for caliper from caliper mounting
-4mm from wheel spacers for correct disc to caliper alignment
summary / need
29.5mm wheel spacers
10mm caliper mounting bolt spacers
10mm longer 675r caliper mounting bolts
25mm diameter axle bolt maybe ZX-14, 06-09 zx10, 07-08 zx6
GSXR k4/5 forks
CBR1000RR 2009- 2016 calipers = CBR600RR 2009-2017
VFR750 RC24 standard steering stem
CBR600RR 2007 - 2012 yokes (top bored to 50mm)
1994 gsxr 1100  http://vfrworld.com/forums/showthread.php/18304-Best-GSXR-fork-upgrade-for-86-VFR?p=127071&viewfull=1#post127071
Rear end
vfr800 gen 5 swingarm, hub, wheel, disc 1998-2001
Speed triple rear axle, disc sprocket carrier
Triumph Speed Triple rear wheel  pirat
order bearings to fit the swingarm to the 86 frame bolts
The OE 01 bearing needs to cut down in length to 45mm and the ID was cut to match the OD of the 86 left pin
Yamaha V Star 650 rear shock with custom dogs
The sprocket (front) needs to have a 5/8" / 15.875mm offset - may have clutch slave clearance issue
The wheel is off to the right 1.5-2.0 mm so the wheel or possibly the hub will have to be milled to correct
17 or 17.5mm wheel offset is needed - if wheel is not milled can the hub be milled?
Honda civic has the same lug pattern/offset
Other wheel sizes
3rd gen wheel 5.5
4th gen wheel 5.0
5th gen wheel 5.5
6th gen wheel 5.5
Modification ideas
Relocate ignition switch
7" naked headlight - cb1300
relocate the oil cooler behind the exhaust headers and cover with a custom grill to prevent stone damage
twin under-seat exhaust (may stick with single) - possible cbr600rr5
rear sets
clipons
bar end mirrors
custom seat cover
single sided paddock stand.
spare set of clocks for loom, custom dash and fusebox relocation
Spare subframe for making brackets for the underseat exhaust fitting and rear mudguard
Parts bought
BikeYearPart name
Triumph Tiger 10502008 Nissin Brake Calipers and master cylinder 108mm between mounting bolts
Triumph Speed triple SE 10502010Front (with discs) and rear wheels
Triumph Street triple 675R2009Bottom yoke
Triumph Speed triple 1050n/aExhaust link pipe
Honda VFR800 fi gen 5n/aSwingarm, hub, caliper mounting
Triumph Sprint ST 9551999Rear Disc, Sprocket, Hub Drive
Knights notes
Measure your headstock and then find out the measurement for the bike you want to donate from.
If they are the same (obviously as well as bearings) then that part would be a straight swap.
Other useful threads for reference
Brake master cylinders
http://www.customfighters.com/forums/showthread.php?t=56704
trail calculator for front forks
http://www.racetech.com/download/TrailCalculator.xls
Upside down forks
Oil cooler relocation idea & hoses
http://www.customfighters.com/forums/showthread.php?t=126673&page=3
Paint
Colour code pb161
http://www.johndaveypaints.co.uk
http://www.rsbikepaint.com/en-gb/colours.php
Filler
Davids Isopon P38 600ml
random thing about batteries
http://vfrworld.com/forums/showthread.php/22254-Ghost-says-quot-Lets-learn-about-batteries!-quot
Street fighter notes Empty Re: Street fighter notes
Post by Jameshambleton on Tue 31 Oct 2017, 10:15 am
Bump, I've been decently active with acquiring parts for this build and excessive research done.
Mocked this up today and it made me smile.
Street fighter notes Y4m7KFwaG2rJbTwfrJsuVUwIzj0P5kLcHfzFJHgUnS94gRIABVHApVg-bwDlvhyPmCabcmw5AkAFQXHt6gwDn0KNQ8YUhEnutZfMUhsBMuyWtvcMO9ulgCcfIlCC-TLmjyHVQwlhD7Suix78A28xAZd8No67IatWslJuJjDReMdUgAHK-9b7fP0-oD2NrxMkbhfPhUyYMi32pRDpUdmisLwHQ?width=4128&height=2322&cropmode=none
 Since I've entered the winter 2018 build off on Customfighters.com I'll mirror posts here if anyone interested?
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Tue 31 Oct 2017, 5:56 pm
I like the novel use of a pair of wellies Laughing Very Happy.
Last edited by Crash- Elmit on Thu 02 Nov 2017, 1:22 am; edited 1 time in total (Reason for editing : just noticed the spelling error)
Post by eternally_troubled on Tue 31 Oct 2017, 10:55 pm
Well, I for one, would be interested in this, so feel free to mirror the posts here. If you can't be bothered or don't have time then just post links to customfighters....
    Current date/time is Tue 23 Jul 2019, 6:37 am
