Dremel type tool
Dremel type tool Empty Dremel type tool
Post by wornsprokets on Sun 02 Apr 2017, 10:07 am
I am thinking of buying a dremel type tool(or cheaper version corded)any recommendations? I had to replace butchered ignition on cb500s...it wasnt pleasent with a drill & 4inch grinder. Whats point of shear/security bolts on ignition barrel? ......dremel would been so handy.....i dont really want to pay dremel prices so a copy version of it?
Dremel type tool 20170401_170931_zpsswv4cgah
The top yoke off. To work on..front end up off the ground also
Fair Weather Rider
Fair Weather Rider
Dremel type tool Empty Re: Dremel type tool
Post by Fair Weather Rider on Sun 02 Apr 2017, 1:09 pm
Wouldn't be with out mine, so handy for all sorts of jobs.
I have got the Aldi Model and no complaints, have just ordered a new set of cutting blades for it off eBay, parts are readily available.
Happy Days.
biglee
biglee
Post by biglee on Sun 02 Apr 2017, 2:11 pm
hi i bought one from macro  in a metal case with drill press/stand and 200 bits and ;pieces sanding discs cutting things polishing ect 25 quid
Post by sullivj on Sun 02 Apr 2017, 4:51 pm
I posted a link to mine on here a while ago. Great bit of kit.. I'll see if I can find it..
Post by sullivj on Sun 02 Apr 2017, 4:57 pm
This was it, although it was only £25 when I bought it.
http://www.ebay.co.uk/itm/FERM-CTM1012-Combitool-Multitool-Combi-Tool-Rotary-Combitool-160W-40-/132092720277?hash=item1ec156f495
Post by eternally_troubled on Mon 03 Apr 2017, 9:31 am
I got this Draper one from Toolstation (it was around £25):
http://www.drapertools.com/product/53106/135W-230V-Multi-Tool-with-56-Piece-Accessory-Kit
Seems fine, I've abused it a little and it hasn't given up yet, however I would suspect that at this price-point it will give up eventually (however this isn't a problem as I don't use it *that* often).
Don't think you have 'Toolstation' in Ireland, but I'm sure you can get it somewhere else...
ratatooie
ratatooie
Post by ratatooie on Mon 03 Apr 2017, 9:44 am
My go to one (which includes a stand and long extension bit to give you lots of flexibility) was an Amazon special and I think was the best reviewed one on there at the time if that counts for anything. It is still the same price I paid
I also paired it with a 400 piece bit set (even though it comes with a token set), which has been fine for everything that I have thrown at it so far.
I think my only criticism is that it possibly doesn't go as fast at top speed as I remember that my previous one did, but I may also be mistaken.
Post by Beresford on Mon 03 Apr 2017, 11:06 am
Where has the best value for tool sets at the moment ?
Post by wornsprokets on Mon 03 Apr 2017, 12:59 pm
As in dremel type tools not sure as in rachet sets has to be halfrauds beresford
Post by Beresford on Mon 03 Apr 2017, 8:56 pm
Yep. Dremel type I mean.
Post by Jameshambleton on Mon 03 Apr 2017, 8:58 pm
Isn't a dremel just a brand like hoover?  scratch
Isn't a "dremel" just a small die grinder?
Post by wornsprokets on Mon 03 Apr 2017, 9:01 pm
Dremel a brand...its a small multi tool... small different tool heads... grinder& sander... ect very handy for bike where you cant get bigger tool in tight spaces
Post by eternally_troubled on Wed 05 Apr 2017, 10:41 pm
@Jameshambleton wrote:Isn't a dremel just a brand like hoover?  :scratch:
Yes, smaller than most die grinders though. Plus die grinders are sometimes air powered.
I suspect that *some* 'dremmel-esque' tools *may* have higher possible speeds than a 'traditional' die grinder, also.
    Current date/time is Mon 16 Sep 2019, 9:13 pm
