front brake an luggage rack
Chrisc54
Post by Chrisc54 on Thu 16 Mar 2017, 5:18 am
morning all ive got a 96 cb500 and im after either a nissin caliper as cant find any on ebay
or a brembo master cylinder as can only find brembo calipers on ebay
also looking for a top box rack
im located in swindon so willing to travel if local ish or will pay postage
cheers chris
Re: front brake an luggage rack
Post by ANDYC on Thu 16 Mar 2017, 7:33 am
Hi Chris, I'm sure that I can help with the brakes.
I'll check this morning and let you know.
Post by ANDYC on Thu 16 Mar 2017, 11:19 am
There is a choice of Nissin or Brembo, the Nissin one is a little cosmetically challenged compared to the Brembo one.
You don't need to change the master cylinder, you can interchange them and they work equally as well.
The only difference to be aware of is the different thread for the banjo bolt. As both of these come with the relative banjo bolt it's not an issue.
Either one is £40 plus postage, or you can collect from the Windsor area.
Chrisc54
Post by Chrisc54 on Thu 16 Mar 2017, 5:13 pm
will pm you
Post by Jameshambleton on Fri 02 Jun 2017, 10:18 pm
Are you still in need of a nissin front master cylinder?
    Current date/time is Mon 22 Jan 2018, 11:48 pm
