renthal ultra low or renthal flats?
yezmike
yezmike
Solved renthal ultra low or renthal flats?
Post by yezmike on Fri 10 Mar 2017, 4:05 pm
i am really stuck between ultra lows and flats, i feel the flats will be easier to fit for cabling however feel they may be to low...
looking for people with both ultra low and flats to let me know the pro and con, thank you
Solved Re: renthal ultra low or renthal flats?
Post by ceejay on Fri 10 Mar 2017, 5:57 pm
Hi and welcome,
I have ultra lows and you don't have to do any major rerouting of cables, however they are probably not far off the limit - I likely wouldn't go any higher but looks like you're not considering that anyway. Had them for a few years and thousands of miles, no issues yet. If you currently have OEM bars they are similar rise but have less sweep meaning the controls are slightly further from the centre of the bike than they were. I don't use bar end weights with them either and get less vibes than originals.
Not tried flats.
Post by Jameshambleton on Fri 10 Mar 2017, 6:42 pm
@yezmike wrote:i am really stuck between ultra lows and flats, i feel the flats will be easier to fit for cabling however feel they may be to low...
Wecome to the forum. There is some some details of this on my post
http://www.cb500club.net/t4699-spec-stats#42587
turista
turista
Post by turista on Mon 07 May 2018, 10:59 am
I put renthal 759 bars on mine and they fit without problems, no issues once clutch cable is rerouted. However they transmit more vibes than oem because they don't have weights inside, I think only fasst make those. Thinking about buying flat bars as they are lower and better for attack mode
Post by Beresford on Mon 07 May 2018, 12:56 pm
I like adjustable bars. I'm tempted to try a set of these
And they're about the same price as Renthals
Edit. A bit dearer than ordinary Renthals but much cheaper than Renthal adjustables.
Post by Jameshambleton on Tue 08 May 2018, 8:22 am
@Beresford wrote:I like adjustable bars. I'm tempted to try a set of these
It's funny how you just linked them as I bought them last week for the streetfighter but for 50mm forks https://www.ebay.co.uk/itm/132496901995
Post by Beresford on Tue 08 May 2018, 3:19 pm
@Jameshambleton wrote:It's funny how you just linked them as I bought them last week for the streetfighter but for 50mm forks https://www.ebay.co.uk/itm/132496901995
What do you think of them James?
I see they are only on offer for 50mm tubes, but I have a friend with the facilities to make a sleeve to adapt them to the slimmer CB stanchion.
Grarea
Grarea
Post by Grarea on Tue 08 May 2018, 4:36 pm
They look interesting.
At some point I would like to fiddle with my position.
Post by Beresford on Tue 08 May 2018, 7:17 pm
@Grarea wrote:At some point I would like to fiddle with my position.
At your age ?!
Grarea
Grarea
Post by Grarea on Tue 08 May 2018, 8:26 pm
Well, not in public.....
Post by Jameshambleton on Tue 08 May 2018, 9:55 pm
Back onto the topic of things... They've not come yet but should be here in a few weeks.
Post by eternally_troubled on Sun 13 May 2018, 11:57 am
Well...
My bike was 'modified' before I got it and (in my ownership) has only had Renthals - mine say Renthal 758' on them, which I learn (from https://road.renthal.com/shop/road-products/road-handlebars/road-se-bars) are 'road ultra-lows'. Don't know if the previous owner had to modify them - probably not.
Post by Beresford on Wed 30 May 2018, 9:08 pm
@Jameshambleton wrote:Back onto the topic of things... They've not come yet but should be here in a few weeks.
Any sign of the adjustables yet James ?
You'll need them now of course, with your left hand on backwards an' all ?
Rolling Eyes
Post by Jameshambleton on Thu 31 May 2018, 8:16 am
Rolling Eyes
Funny how you should post - they haven't come and the tracking says so too. I contacted the seller and they're sending me replacements with priority mailing.
I'm secretly hoping that the lost one finds its way here eventually
    Current date/time is Sun 24 Mar 2019, 7:27 pm
