clutch issues
Crash- Elmit
Crash- Elmit
clutch issues - Page 2 Empty Re: clutch issues
Post by Crash- Elmit on Tue 07 Mar 2017, 10:16 pm
This is the stuff I was talking about.
http://www.centuryspring.com/urethane
Chrisc54
Post by Chrisc54 on Tue 07 Mar 2017, 10:19 pm
@Crash- Elmit wrote:This is the stuff I was talking about.
thats the stuff i can get at work
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Tue 07 Mar 2017, 10:47 pm
If I remember correctly the colour denotes the strength of the urethane, and red is the strongest.
Post by ANDYC on Wed 08 Mar 2017, 10:22 am
@Crash- Elmit wrote:If I remember correctly the colour denotes the strength of the urethane, and red is the strongest.
The problem with urethane is it doesn't respond well to high temperatures and isn't recommended for use over 80 degrees.
I'm going to give Viton a try, it's good up to 200 degrees and resilient to most oils and fluids.
Most engines keep the oil at around 120 degrees, I will be fitting an oil temp gauge just to check. Although I have only ever seen an oil temp gauge capable of measuring up to 150 degrees. Top quality valve stem seals are made of Viton, so there must be something to it as the valves get much hotter than the clutch backplate ever will. (I hope)
There are small posts where the rivets or in my case screws go to act as spacers to allow movement between the basket and the backplate.
Chrisc54
Post by Chrisc54 on Wed 08 Mar 2017, 7:09 pm
ah thats a shame the urethane wouldnt be any good
where abouts did you get hold of the viton from?
will add some to the list of bits to buy for my cb
Post by ANDYC on Wed 08 Mar 2017, 8:32 pm
I  was wondering that myself this morning as I wrote that post.
It's come to my attention that because this project has already taken so long to come this close to fruition for one reason or another I'm beginning to loose track of different parts of it.
I searched everywhere to find the receipt for the viton but to no avail.
A good supplier should be able to get some though.
Chrisc54
Post by Chrisc54 on Fri 10 Mar 2017, 11:31 pm
@ANDYC wrote:I  was wondering that myself this morning as I wrote that post.
no worries, thanks for looking
have found a couple of places online that sell it so once ive got a spare basket to play with ill give the mod a try as the clutch rattle annoys the hell out of me
Boodysaspie
Boodysaspie
Post by Boodysaspie on Sun 12 Mar 2017, 7:44 pm
My basket's so noisy, I daren't let the clutch out ...
Pretty please, will someone point me to the relevant page(s) in either the Haynes or the, ahem, manual?
Ta muchly.
Chrisc54
Post by Chrisc54 on Fri 17 Mar 2017, 7:21 pm
@Boodysaspie wrote:My basket's so noisy, I daren't let the clutch out ...
Ta muchly.
not really much ive seen in the haynes manual about the clutch rattling
Chrisc54
Post by Chrisc54 on Fri 17 Mar 2017, 7:25 pm
have now slightly reduced my clutch rattle by shimming 2 of the springs and replacing the other 2 with some i had laying around from a suzuki bandit that were around 1cm longer
will get another clutch basket next week as the springs in the back are loose as hell, a couple have 3-4mm of play in the slot
Post by Beresford on Fri 17 Mar 2017, 8:08 pm
@ANDYC wrote:A good supplier should be able to get some though.
What diameter is required ? Can someone measure the springs and basket recess and post it up here please ?
gopher
gopher
Post by gopher on Fri 17 Mar 2017, 11:37 pm
Saw some Viton cord on eBay up to 10mm diameter , may do the job?
Post by ANDYC on Sat 18 Mar 2017, 9:08 am
I'm using 21mm diameter viton cord.
    Current date/time is Mon 20 May 2019, 8:14 am
