Front brake disc
Front brake disc
Post by Beresford on Sat 18 Feb 2017, 10:39 pm
Unfortunately, my front disc is well past the 4mm wear limit so a replacement is needed, urgentlyish (even though it is stll working perfectly).
Is the front disc the same for Nissin and Brembo, as the part number seems to change through the years ?
Re: Front brake disc
Post by Jameshambleton on Sat 18 Feb 2017, 10:44 pm
Same disc throughout all of the years.
Post by Beresford on Sat 18 Feb 2017, 10:55 pm
Thank you for that, James.
Post by Jameshambleton on Sat 18 Feb 2017, 11:00 pm
If you fancy doing a bit of cross referencing the disc is also used on these other models.
HONDA
CB 500 R/T (1994>1996) FRONT
CB 500 V/W/SW/X/SX/Y/SY/2/S2 (1997>2003) FRONT
CBF 600 N4/S4/N5/N6 (2004>2006) FRONT
CBF 600 NA4/NA5/NA6 (ABS Model) (2004>2006) FRONT
CBF 600 S4/S5 (Non ABS) (2004>2005) FRONT
CBF 600 SA4/SA5/SA6/SA7 (ABS Model) (2004>2008) FRONT
NT 650 VW/VX/VY/V1 Deauville (1998>2001) FRONT
NT 650 V2/V3/V4/V5 Deauville ? (2002>2005) FRONT
NT 700 V6/V7/V8/VA Deauville (2006>2010) FRONT
NT 700 VA6/VA7/VA8/VAA Deauville (2007>2010) FRONT
CB 750 F2N/F2R/F2S/F2T/F2V/F2W/F2X/F2Y/F21 CB Seven  (1992>2002) FRONT
VFR 750 FJ/FK (1988>1989) FRONT
VFR 750 FL/FM/FN/FP (1990>1993) FRONT
CBR 1000 FH/FJ (1987>1988) FRONT
CBR 1000 FK/FL/FM/FN (1989>1992) FRONT
CBR 1000 FP/FR/FS/FT/FV/FW/FX (1993>1999) FRONT
ST 1100 AT/AV/AW/AX/AY/A1/A2 (Pan European - ABS Mode (1996>2002) FRONT
Post by Beresford on Sun 19 Feb 2017, 12:52 am
Being used on all those models, you'd think the production cost would be low and so the price. But at £75 -£95 it seems like a very expensive punched out plate of steel !
Post by wornsprokets on Sun 19 Feb 2017, 1:09 pm
Nothing new with honda and there parts prices
burning_rubber
Post by burning_rubber on Tue 28 Feb 2017, 10:33 pm
@Jameshambleton wrote:If you fancy doing a bit of cross referencing the disc is also used on these other models.
HONDA
thanks for this amazing list ill take a chance on a vfr750 one, i've always wondered how people know what parts fit what bikes
Post by Jameshambleton on Tue 28 Feb 2017, 10:37 pm
HONDA
If you ever need owt cross-referencing let me know Wink
May as well post the rear disc too
NSS 250 EX5/EX6 Forza EX (ABS) (2005>2006) REAR
NSS 250 AX5/AX6 Forza Z (ABS) (2005>2006) REAR
CB-1 (CB 400 F) (1989>1990) REAR
CB 400 SF (F2N/F2R/F2S/F2T/F3S) Superfour (NC31) (1992>1995) REAR
CB 400 SF (F2V/F3T) Superfour (NC31) (1996>1997) REAR
CB 400 SF (F3V) Superfour (NC31) (1997) REAR
CB 400 Four V/V-II/W/W-II (NC36) (1997>1998) REAR
CB 500 V/W/SW/X/SX/Y/SY/2/S2 (1997>2003) REAR
CB 750 F2N/F2R/F2S/F2T/F2V/F2W/F2X/F2Y/F21 CB Seven  (1992>2002) REAR
CB 900 F2/F3/F4/F5/F6/F7 Hornet (2002>2007) REAR
Post by eternally_troubled on Thu 02 Mar 2017, 11:57 am
@wornsprokets wrote:Nothing new with honda and there parts prices
True, it is often not cheap.  You are paying the price for them buying extra parts (not that much) and the storing (at least some of) them for 20+ years (more expensive!).
Part of the reason that after-market parts are cheaper is that they only bother to make them now and not have to store them or pay manufacturers to keep making them. This is why there are only (usually) consumable parts that are made after market - there is an inbuilt market for them (brake pads, for example).
    Current date/time is Tue 22 May 2018, 10:54 am
