TEC shocks CB500s
Scorgie88
TEC shocks CB500s
Post by Scorgie88 on Thu 16 Feb 2017, 8:27 pm
Evening all,
I'm one the verge of buying some TEC shocks but was wondering if anyone knows if the sizes are the same on the cb500s as on the naked? The Haynes only gives the spring free length and I'm not even sure what that is.
Ta
Rob
Re: TEC shocks CB500s
Post by Jameshambleton on Thu 16 Feb 2017, 8:53 pm
I believe they are the same. The TEC ones are 350mm so 10mm longer than stock so if you've got a mainstand both wheels may not come off the floor. If you're not use to them then they can be reasonably hard until you get use to them
Scorgie88
Post by Scorgie88 on Thu 16 Feb 2017, 8:59 pm
I reckon that'll be ok, I find the OE ones a bit soft most of the time.
Cheers!
Post by wornsprokets on Thu 16 Feb 2017, 9:25 pm
Ive a set of tec shock on my 97 cb last two yrs , there very good .but there longer than original ones as when u put bike on centre stand.rear wheel on the ground so u cant spin wheel
Scorgie88
Post by Scorgie88 on Thu 16 Feb 2017, 9:41 pm
Got to be worth a go for £50, they seem to have mostly good reviews.
Post by wornsprokets on Thu 16 Feb 2017, 9:58 pm
Ive 10k  miles on them  now there as good as expensive versions ive done motorways and rough dublin city  raveged pothole streets...i havent adjusted them so far...i near bought two pair they were so cheap
Scorgie88
Post by Scorgie88 on Thu 16 Feb 2017, 10:06 pm
Good to hear, cheers mate. Gonna look like new with new shocks and my shiny new exhaust. No less than it deserves!
Crash- Elmit
Post by Crash- Elmit on Thu 16 Feb 2017, 10:14 pm
I fitted a set to my 94r in Dec last year. Due to the cancer the bike stood unused all through January and they have already begun to rust, quite badly actually, so took them off Tuesday at garage and fitted the RFY gas shocks I bought off Ebay.  They appear to have a good finish so should last.
Post by wornsprokets on Thu 16 Feb 2017, 10:25 pm
My bike been outside last two years...  very little on tec shocks....we dont use  as much salt as in uk
Post by wornsprokets on Thu 16 Feb 2017, 10:34 pm
I put pic up of my tec shocks up tomoro there condition after 10k... if you ride in salt are you not ment to wash bike after with cold water .i also coated them with acf50(once only
Post by Jameshambleton on Thu 16 Feb 2017, 10:42 pm
My Tec shocks have been through 2 winters now and are at least 3 years old! One only has rust from pitting nothing much as it comes off with the polishing action of an old sock and that has only really happened these last few weeks. I've got a spare set sitting in my wardrobe.
I've done 18,797 miles with these fitted + a couple of hundred when my dad rode my bike and then the previous owners 800 or so miles
Post by wornsprokets on Mon 20 Feb 2017, 6:34 pm
my  tec shocks after two yrs and 10k miles     my cb lived outside under a cover up to october of last years.... i sprayed the tec shocks once with acf50... bike used every day ....no rust just dirt. Also while ago there was salt on road cant remember last time i washed cb...
    Current date/time is Fri 22 Jun 2018, 3:46 pm
