heated gloves
biglee
heated gloves
Post by biglee on Tue 31 Jan 2017, 8:05 pm
hi i am looking for some advice on batterry heated gloves,
can anyone recommend a good pair and a good place to buy them from thanks in advance
Re: heated gloves
Post by eternally_troubled on Wed 01 Feb 2017, 9:07 am
Are they for use on the bike?
I think Gerbing are the brand - they have a lifetime warranty (they also do non-bike heated things).
If you are going to use them on the bike then go for ones that plug in to the bike (rather than battery ones) - the annoyance of the batteries running out is more than the annoyance of having a wire!
Re: heated gloves
Post by ceejay on Wed 01 Feb 2017, 10:41 am
I have Gerbing heated gloves. They have been reliable in all weathers for a couple of years now. I feel my hands get cold easily and I have never had to set them higher than medium even on long hauls in UK winter temperatures. They basically solved the problem of cold hands all together for me. I do have them wired to my bike though. There are pockets/options for batteries but like ET said cons can outweigh pros on that one.
Re: heated gloves
Post by eternally_troubled on Thu 02 Feb 2017, 9:38 am
@ceejay wrote:There are pockets/options for batteries but like ET said cons can outweigh pros on that one.
I have just thought slightly harder about that - if you had more than one bike I can see why you might want the battery ones - plus I realise that putting 2 sockets on 2 bikes might be more annoying.
biglee
heated gloves
Post by biglee on Thu 02 Feb 2017, 8:29 pm
hi all i have been offered a new pair of plus venture 7.2 litheriam battery with 4 heat settings lowest heat aprox 5 hours on high aprox 2 hours for 60 quid  i looked on line they retail at 149.99
Re: heated gloves
Post by ceejay on Sat 04 Feb 2017, 10:43 pm
It is just a small piece of wire running from the battery to a single connector that you'd need two of. The control unit and cables to the gloves stay in my jacket. I connect that to the bike at the bottom of the jacket then connect the gloves at the sleeves of the jacket. If you're on and off your bike a lot in your day I can see how it'd be a bit of a pain but for long hauls it's great. I did think about mounting the control unit and cables to the bike itself to reduce the amount of connecting each time from 3 to 2 but haven't attempted that yet.
I guess with batteries you could use them on your push bike too : )
biglee
heated gloves
Post by biglee on Sat 11 Feb 2017, 6:37 pm
hi all i today purchased a pair of rst thermotech heated gloves got them for 149 so pretty resanable  i went for these after some intence reserch they seemed to be the best of the bunch all round plus trhe spare battery packs are only 24 quid
Re: heated gloves
    Current date/time is Mon 16 Jul 2018, 4:12 am
