Brake bleed nipple M8 or M10
Post by muttley1 on Mon 09 Jan 2017, 7:06 pm
I'm doing a brake overhaul and thought I'd change the bleed nipple whilst I'm at it. There are plenty on fleabay for a couple of quid. The caliper is Brembo so does anyone know if I'd need an M8 or M10 fitting?
cheers
Re: Brake bleed nipple M8 or M10
Post by liverpool_f_ on Mon 09 Jan 2017, 9:42 pm
As far as I remember, you need an 11mm spanner on mine. I only remembered that because it's the only time I have ever used an 11mm spanner. I think the nipple is original
Post by eternally_troubled on Wed 11 Jan 2017, 8:58 am
I can't remember! When I get a moment I will measure the bit that is sticking out of the caliper.... if I had to guess I'd say the smaller one.
Additional: could it be M6:
http://www.ebay.co.uk/itm/Brake-Caliper-Bleed-Screws-Nipples-M6-x-1mm-Pitch-Pack-2-/201542841080?hash=item2eece3b2f8:g:CY0AAOSwP~tW6T4d
That isn't making this any better..... sorry!
    Current date/time is Tue 22 May 2018, 10:50 am
