Frauds of half oil back on offer
Post by Jameshambleton on Sun 25 Dec 2016, 10:10 pm
So after the long discussions of this time last year I've been using this without issue and it's back and it's at the same price as last year to £12 for 4 liters.
Frauds of half
Re: Frauds of half oil back on offer
Post by Beresford on Mon 26 Dec 2016, 1:11 am
And this, which I've also used
http://www.halfords.com/motoring/engine-oils-fluids/engine-oil/halfords-5w40-fully-synthetic-oil-4l
same price.
Post by Jameshambleton on Mon 26 Dec 2016, 9:38 am
@Beresford wrote:And this, which I've also used
same price.
I've been told that you shouldn't use fully synthetic as it affects the way the bearings in the engine move, fully synth makes them skid rather than roll as they should do. As there wasn't fully synthetic when our engine was designed.
Post by wornsprokets on Mon 26 Dec 2016, 10:31 am
I think full synthetic is a better oil but ive heard that in likes of old yamahas that use to drink oil like yzf 750 & fzr 1000...it make it worse as in consumption  as its a thinner oil...also clutch slip...but i cant be sure of this, i use semi in my old fireblade
Post by Beresford on Mon 26 Dec 2016, 10:37 am
This sounds like a confusion between the behaviour of roller/ball bearings with plain bearings.
The most important consideration with an oil is the film strength where the nose of the camshaft lobes bear on the followers, as this is where the oil is under maximum stress. Modern fully synthetic oils tend to be better in this respect.
Post by Jameshambleton on Mon 26 Dec 2016, 3:21 pm
I've found that they hide these very well amongst the other oils, usually a single row next to the 5 liter bottles. I've just bought 4 bottles but I'm going to get a couple more, 4 bottles should last me for the year but now with having 3 bikes I may need some more.
Post by wornsprokets on Mon 26 Dec 2016, 3:24 pm
I used 10/40  semi in cb and no probs .. james going get few cans  in next few days
Post by Beresford on Mon 26 Dec 2016, 4:03 pm
I've just visited one of the local stores here (Bangor) and they had a pile of the 4L £12 oils on display in front of the main cash desk, so you couldn't miss them. I wonder how long that offer will last ? I bought a couple as the CB is due a change in about 1000 miles, for me that would be approaching Easter, and I'll bet that the offer would be over then! I use the same oil in the Tiger, but that isn't due until the summer, and when it's due I'll be feeling great smugness ! cheers
Post by wornsprokets on Mon 26 Dec 2016, 4:43 pm
What you using beresford, fully synthetic in the cb? I say offer last til end of jan....
Post by Beresford on Mon 26 Dec 2016, 9:27 pm
@wornsprokets wrote:fully synthetic in the cb?
Yep
Post by eternally_troubled on Tue 27 Dec 2016, 11:05 am
same price.
You *can* have problems with some types of ball-bearings, in some situations. Our engine (in the cb500) has plain bearings for the most critical parts, so the rotating part is constantly 'skidding' on a film of pressurised oil all the time anyway - I'm pretty sure you can use fully synth in the cb500.
Post by wornsprokets on Tue 27 Dec 2016, 1:13 pm
Have you a fairly new clutch in the cb beresford...i taught fully synthetic cause clutch slip in old bikes
Post by Beresford on Tue 27 Dec 2016, 5:25 pm
18,000 miles
My CB and my Tiger are the same year - 2003. When new, Triumph recommended Mobil 1 synthetic for the Tiger which has a wet clutch. Mobil 1 is a high quality general purpose car oil, so since then I have always used full synthetics in my bikes with no clutch issues.
Post by eternally_troubled on Wed 28 Dec 2016, 7:34 am
@wornsprokets wrote:Have you a fairly new clutch in the cb beresford...i taught fully synthetic cause clutch slip in old bikes
Not normally - it's the friction modifiers (additives to make oil flow more efficiently) in 'high efficiency' oils which usually cause clutch problems - it shouldn't be a problem as long as you stay away from any oils that suggest they improve your miles-per-gallon! The synthetic oil by itself isn't the problem...
    Current date/time is Thu 19 Jul 2018, 10:35 am
