Engine Oil - Have I made a mistake?
Vardypeeps
Post by Vardypeeps on Tue 06 Dec 2016, 6:23 pm
Hello.
I noticed that in my Haynes manual the other day it states 10x30 should be used for engine and transmission.
I'm not certain what grade of oil is in at the moment as it was done by the previous owner but I have been topping up with 10w40 (kicking myself over this, just assumed it was 10w40).
Can 95 CB500 be run on the thicker 10w40 with no effect to engine life? I think it takes longer to warm up?
Thank You Smile
Re: Engine Oil - Have I made a mistake?
Post by sullivj on Tue 06 Dec 2016, 6:27 pm
Yes, I've used 10/40 in mine for years with no issues.
Post by liverpool_f_ on Tue 06 Dec 2016, 6:47 pm
Also, the US military are very clever folks and it was they that came up with the system for grading oil. Their system allows mixing of different grades with no problems. All that happens is you end up with something somewhere in the middle. So if 10w30 was in there and you add an equal amount of 10w40, all that happens is you end up with 10w35.
If the previous owner did the last oil change however, I strongly suggest you do a new one regardless of when they said it was done. Best be sure.
Vardypeeps
Post by Vardypeeps on Wed 07 Dec 2016, 10:46 am
Liverpool, totally agree and it's next on the list but Thanks for confirming regarding the 10w40 Sullvj.
I didn't think it would too much of an issue and confirming youve used 10w40 for ages I'm happy now!
Just covering everything to make sure I'm not going to blow the CB in the near future Razz Not that a CB500 can be blown up?!
Post by eternally_troubled on Wed 07 Dec 2016, 1:27 pm
It's really quite hard to buy 10W30 these days. So many (hundred) of thousands of miles must have been travelled by people on CB500s running 10W40 (and probably not even *good* 10W40!) I would have thought any problems would have shown up by now.
    Current date/time is Thu 26 Apr 2018, 2:03 pm
