cures for a waggly side stand?
Post by trevor machine on Mon 05 Dec 2016, 11:16 am
Previous owners weren't as diligent as me when it comes to the lubrication of all points pivotal. Uncaring bastards. Consequently they've left me with a side stand that's got a fair amount of play in it - most up and down, but a bit in every direction tbh. I also note that there are two springs on it - as though someone's tried to address the issue previously.
Is it the stand worn, or the frame side of things? It's only a niggle - but if I can do more to stem the wear than just oiling the damn thing, I sort of feel like I should.
Re: cures for a waggly side stand?
Post by sullivj on Mon 05 Dec 2016, 11:53 am
@trevor machine wrote:Previous owners weren't as diligent as me when it comes to the lubrication of all points pivotal. Uncaring bastards. Consequently they've left me with a side stand that's got a fair amount of play in it - most up and down, but a bit in every direction tbh. I also note that there are two springs on it - as though someone's tried to address the issue previously.
I think they have two spings as standard - one inside the other.
I think the hole that the bolt passes through, enlarges over time.  Is that right?
Mine also has some play in it, which makes the bike lean over more than I would like.  I've considered welding a plate to the bottom of a side stand to make it stand the bike up better.  I would prefer a better solution though, so will follow your progress..
Post by teamster1975 on Mon 05 Dec 2016, 4:47 pm
There are a few things to check and it's all down to wear.
The hole in the frame elongates, the hole in the side stand elongates, the shank on the bolt wears away, and most worrying the lug that the springs hook onto on the frame will wear away so check that!!!
Post by sullivj on Mon 05 Dec 2016, 5:21 pm
Thanks Teamster - I'll have a closer look.
Post by trevor machine on Mon 05 Dec 2016, 5:46 pm
Yeah cheers for that. ; - )
Post by Jameshambleton on Mon 05 Dec 2016, 7:36 pm
All of the side stands on my bikes have loads of left and right movement, I'm sure it could be fixed with a few washers but its never really bothered me.  I remember reading somewhere on here that the spring lug on the frame once snapped through.
Post by eternally_troubled on Tue 06 Dec 2016, 7:34 am
I bet it is all three: the hole in the frame, the hole in the stand and the bolt!
The bolt can be replaced, possibly the stand can be replaced but the frame would have to be welded to fix it (*if* it is possible).
The good thing is that if you replace 2 out of 3 (say, bolt and stand) then the wiggle should at least reduce (unless the hole in your frame is really shagged).
Mine is doing something similar and I haven't looked at it yet... I think this is just 'one of those things' that happens (and I haven't got round to fixing yet!).
Post by trevor machine on Tue 06 Dec 2016, 9:34 am
Thanks ET. Helpful, that.
Post by teamster1975 on Tue 06 Dec 2016, 2:16 pm
I have replaced the side stand and springs and it's a lot better, the inner spring had actually rusted through! The bolt is cream crackered though and the spring lug needs attention, plus the wear in the frame. I can't really grumble for a nearly 20 year old bike, it still does me proud Smile
Post by eternally_troubled on Wed 07 Dec 2016, 1:15 pm
@teamster1975 wrote:I have replaced the side stand and springs and it's a lot better, the inner spring had actually rusted through! The bolt is cream crackered though and the spring lug needs attention, plus the wear in the frame. I can't really grumble for a nearly 20 year old bike, it still does me proud :)
That sounds positive - like I might not have to weld my frame just yet!
    Current date/time is Fri 20 Jul 2018, 2:02 am
