Gas Solder Iron
Gas Solder Iron
Post by sullivj on Mon 28 Nov 2016, 1:19 pm
Having seen a friend using one, I got one for myself.  Nicely made, and almost instant heat up time.  Saves messing about with cables and waiting for the electric one to heat up.
https://www.amazon.co.uk/gp/product/B002LARRQW/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Re: Gas Solder Iron
Post by ashcroc on Mon 28 Nov 2016, 2:09 pm
Saw something like this about 25 years ago & always regretted not getting it.
They're useful for doing small jobs or even carrying out & about for emergency repairs but I'd couple it with an electric iron for the bigger stuff.  The pyrography looks like a fun pastime.
spanner monkey
Re: Gas Solder Iron
Post by spanner monkey on Mon 28 Nov 2016, 5:15 pm
Yes I've seen a fellow biker using one for small repairs, and it's great for braising, I was trying to get a tiny spot of solder to a pin hole in a tank even with flux and no joy. These things avoid knocking the solder away and every blow it into place. Much more effective. Wish I'd got one years ago, more expensive overall unless they're refillable I guess but much more effective.
Re: Gas Solder Iron
Post by eternally_troubled on Mon 28 Nov 2016, 6:05 pm
My previous employer had one of these: I ended up using it in the car park at lunch time to fix some bits of wiring that had come undone. Worked very well.
An electric soldering iron will always work out cheaper (you fill the above from butane cigarette lighter refill cans, I suspect) but these are good for situations where an extension lead is not an option.
spanner monkey
Re: Gas Solder Iron
Post by spanner monkey on Mon 28 Nov 2016, 7:45 pm
And they fundamentally behave in a different way so worth the extra.
Re: Gas Solder Iron
Post by sullivj on Mon 28 Nov 2016, 8:11 pm
A big can of butane lighter gas to fill this was only £1.50. I imagine it should fill it about 10 times.
Re: Gas Solder Iron
Post by badseeds on Sun 04 Dec 2016, 6:38 am
Shut up and take my money!
Re: Gas Solder Iron
Post by sullivj on Sun 04 Dec 2016, 8:28 am
I only paid £20.47.. It's gone up to £33.55 now?!
Re: Gas Solder Iron
Post by teamster1975 on Sun 04 Dec 2016, 7:12 pm
I've had a Portasol iron for many years, brilliant bit of kit. Total god send when working on vehicles, you get the various size soldering tips, blow torch and hot air attachment for heat shrink, although you can use the side of the catalyst on a soldering tip for heat shrink too.
Re: Gas Solder Iron
    Current date/time is Tue 17 Jul 2018, 4:16 pm
