thermostat o-ring
thermostat o-ring
Post by geewhizz on Sat 19 Nov 2016, 9:54 am
Curious if this is a common part that needs replaced eventually? not sure if mines had its day or just needs nipped up a bit. It costs a satanical £6.66 from D Silver (no. 91311KE8000)
Re: thermostat o-ring
Post by ashcroc on Sat 19 Nov 2016, 12:29 pm
O-rings can perrish over time so it wouldn't surprise me especially if you've recently removed/replaced the stat.
Post by jerryfudd on Sat 19 Nov 2016, 1:05 pm
.......still less than my OE Honda cable tie cost (each!)
Post by ashcroc on Sat 19 Nov 2016, 2:36 pm
Still can't quite believe you went oe for a cable tie!
Post by sullivj on Sat 19 Nov 2016, 3:08 pm
@ashcroc wrote:Still can't quite believe you went oe for a cable tie!
He's struggled to live it down since..
Post by jerryfudd on Sat 19 Nov 2016, 5:44 pm
...but clearly has no shame or regret lol Smile
it was moulded to be exactly the right cable tie for the job - why cut corners at the last hurdle.
    Current date/time is Sun 24 Jun 2018, 7:33 pm
