Digital Gear Selector....!
Post by sullivj on Fri 18 Nov 2016, 9:59 pm
Not exactly subtle, is it?!
Re: Digital Gear Selector....!
Post by Jameshambleton on Fri 18 Nov 2016, 10:17 pm
I don't see the point in gear indicators. If you don't know what gear you're in from the revs and your current speed then you have a problem.
Post by jerryfudd on Sat 19 Nov 2016, 12:25 am
true, although sometimes it's as simple as how is it revving...... too high, go up...... too low or need some poke go down. want to stop all the way down and half up - why bother with labels Smile
Post by trevor machine on Sat 19 Nov 2016, 9:39 am
@Jameshambleton wrote:I don't see the point in gear indicators. If you don't know what gear you're in from the revs and your current speed then you have a problem.
I like when, during TT testing in 1978, mechanic Steve Wynne asked Mike Hailwood what gear he was in at a certain part of the Mallory course. Hailwood said "How many gears does it have?"
Post by jerryfudd on Sat 19 Nov 2016, 9:50 am
haha awesome
Post by Jameshambleton on Sat 19 Nov 2016, 12:12 pm
haha awesome
Kinda like me with my cb400, not a clue if it's got 5 or 6 gears I just use the thing if the revs seems a bit high change up a gear
Post by ashcroc on Sat 19 Nov 2016, 12:19 pm
The only time I've been worried about what gear I'm in is coming up to speed cameras with a broken speedo cable. If it won't go down any more I'm in first & no more up is 6th.
Post by ceejay on Sat 19 Nov 2016, 7:44 pm
I have a terrible habit of looking for 7th gear... even when I know from the revs and my speed I'm in 6th I still sometimes do it just 'to be sure'! I'm the same with cancelling indicators, constantly pressing it even when I know they are off... I have a problem probably.
Post by Jameshambleton on Sat 19 Nov 2016, 7:56 pm
@ceejay wrote:I have a terrible habit of looking for 7th gear... even when I know from the revs and my speed I'm in 6th I still sometimes do it just 'to be sure'! I'm the same with cancelling indicators, constantly pressing it even when I know they are off... I have a problem probably.
And here I was thinking I was the only one!
GlenAnderson
Laser Shark
Laser Shark
Post by GlenAnderson on Sat 19 Nov 2016, 8:03 pm
When the speedo and tacho needles are pointing at roughly the same "O'clock", then you're in top.
Post by eternally_troubled on Sat 19 Nov 2016, 9:24 pm
Is that at 'motorway' speeds? When I first started riding regularly on a motorway with the CB500 I kept getting to about 70 or 80 mph and looking for that extra gear - there wasn't one :)
I generally don't know what gear I'm in; I kind of play it by ear.
That aftermarket gear sensor look quite liable to go wrong when you accidentally give it a kick with your boot.
Post by ceejay on Sat 19 Nov 2016, 9:54 pm
Is that at 'motorway' speeds? When I first started riding regularly on a motorway with the CB500 I kept getting to about 70 or 80 mph and looking for that extra gear - there wasn't one Smile
yep : )
Same!
On the opposite side of things I have twice left it in 5th at 'motorway' speeds (probably when I've sub consciously shifted down in traffic) and only noticed when it hit that surge around 8000rpm! It's not as if I feel it needs another gear though, at 6-7000 in 6th I'm probably going too fast anyway.
I don't think I'd want an gear indicator as it takes away from the simplicity of the bike with little benefit (for me at least). Simple is better sometimes for me - for example I could happily live with non-electric windows in a car because I like the simple mechanical design even though electric windows have never gone wrong in my car anyway! Maybe I am just a simple person!  Smile
Post by sullivj on Sat 19 Nov 2016, 11:58 pm
I wish the CB500 was like my 1957 Ambassador...
When she's in top gear (on the RIGHT HAND SIDE), you can push the lever up against the spring, which allows the lever to travel about 15mm.
If she's not in top gear, you can feel an obvious resistance at the lever, so you know you need to pull the clutch and change again.
Imagine this on the CB... If the lever moves by 15mm, you know you're in top - SIMPLES!
dodger
Post by dodger on Sun 20 Nov 2016, 10:37 am
reading this thread has made me think about something I never used to think about Very Happy
Post by trevor machine on Sun 20 Nov 2016, 11:05 am
Kicking up for seventh is getting less regular but I still do it. Have also sat on the motorway in fifth for a while in the not so distant past. Probably will again. Esp now I wear ear plugs all the time.
Post by teamster1975 on Sun 20 Nov 2016, 6:39 pm
When I'm riding with mates on bigger bikes I sometimes look for 7th gear, we usually do the sensible thing and stick me at the front of the pack Laughing
Baddi
Hyper Viper
Hyper Viper
Post by Baddi on Mon 21 Nov 2016, 8:56 am
I've noticed that in 2nd gear I have 100 rpm per kilometers per hour and in 6th gear I have 50 rpm per kilometers per hour.
This way, if I drive 60 km/h in 2nd gear I'm at 6000 rpm but in 6th gear I will be at 3000 rpm.
The other gears does not end at such a rounded number. Very Happy
That said, the only thing I might use a gear indicator for is to know if I hit 3rd or 2nd gear when I'm decellerating towards a red light and it then turns green again so that I have to accelerate. Some times I end at very high rpm compared to how fast I should accelerate.
    Current date/time is Fri 20 Jul 2018, 2:09 am
