Pulling out caliper pistons
Post by Beresford on Mon 31 Oct 2016, 7:37 pm
Here's a way of pulling the pistons if the caliper is off the bike
http://www.thetriumphforum.co.uk/threads/champagne-is-good-for-your-brakes.7734/
Re: Pulling out caliper pistons
Post by Jameshambleton on Mon 31 Oct 2016, 8:48 pm
I think I'd just some of these
Post by eternally_troubled on Tue 01 Nov 2016, 8:01 am
They essentially do the same thing; the former is more use if you are in a hurry and you can't wait for a delivery!
The other thing I have used with some success is compressed air:  you blow it in via the bleed nipple while stuffing your finger (or other items!) over the bajo-bolt hole, ideally while clamping the other piston in place.  You can do this even if you don't have a compressor - one of those big T-shaped bicycle track pumps works well, assuming you have an assistant to do the pumping!  You need to be careful about aiming the piston away from yourself or anyone else:  when it comes out it goes 'pop' and fires across the room!
Alvi
Post by Alvi on Tue 01 Nov 2016, 8:28 pm
I've used that compressed air method with some success. One piece of advice though, don't try & 'catch' the piston with your fingers as it come out. Firstly,it hurts, a lot. And secondly, being one handed now makes it very difficult to remove the caliper from your other hand!  Sad
Post by ceejay on Tue 01 Nov 2016, 8:48 pm
I second the track pump idea, air compressor not essential. Bag over it to catch the piston has worked for me in the past.
    Current date/time is Sat 21 Apr 2018, 4:48 am
