Project Bandit VVT 400
Project Bandit VVT 400 - Page 2 Empty Re: Project Bandit VVT 400
Post by Jameshambleton on Sat 03 Dec 2016, 10:12 pm
Well not much has been done today even though it has taken the best part of 7 hours.
I fitted the exhaust headers since the bolts came today that were needed to fit it. If anyone needs this info in the future for any reson suzuki l:30 = M8 x 30mm.
I fitted all the bolts apart from one as it wants to cross thread in the head so I'm leaving it for now. But at least the full exhaust system is now installed.
I've managed to fit the sprocket cover and clutch cable and bolt it in place, for some reason suzuki thought running the clutch cable through the front sprocket cover was a good idea, and we know how full of stuff that thing gets.
I tried to make the bike run once again and failed, all plugs have good spark and she still wouldn't fire even with full choke like before. So after I flattened the battery once again I put it on charge and left it.
Went back to it 2 hours later and tried it because why not and she started with full choke so I'm back to the same issue as before - runs on full choke but nothing else, but at least I know the bike runs.
Post by Jameshambleton on Fri 13 Jan 2017, 8:29 pm
Not much to update for now until I get a few more bits sourced from japan and the details of a guy who can do the spraying for me.
But in the mean time I've gotten a few nice things.
New starter cover as the one that i've got has a hole in it so when the brandit is on her side stand she leaks oil. Sadly the cost of used covers were rather expensive so I picked up this little gem for a shocking £12.50 posted  affraid
Project Bandit VVT 400 - Page 2 16105739_709875149186767_3187775485804781796_n
This really did hit the pocket hard, this is also the first new chain that I've ever bought.
Project Bandit VVT 400 - Page 2 15994632_709875112520104_1122588205703875640_o
Post by skyrider on Sat 14 Jan 2017, 9:45 am
its a good make though I like DID chains myself
Post by Jameshambleton on Fri 10 Feb 2017, 9:02 am
Well just a short update at the moment, the bike now revs after washing the carbs in hot water in the sink. Which is a good start. The fork seals are weeping slightly which is a worry.
I've managed to order the parts from Japan, but... I almost cried with the postage cost... £140.
I think the stuff I bid on came to something like £60 in total but then I had to pay postage costs, so Japan - Japan - then to the uk. Should be here in 1-3 months though.... So next update should be April ish
The next job will be chain and sprockets as well as the brakes. I managed to get a pair of ebc pads for £21.94 so that's the front end sorted.
ratatooie
ratatooie
Post by ratatooie on Fri 10 Feb 2017, 9:23 am
@Jameshambleton wrote: the postage cost... £140.
Good grief affraid ! I had a whole bike moved from the UK to IoM for about that.
Post by skyrider on Fri 10 Feb 2017, 10:55 am
iye and that will be with the costa packet prices too Laughing Laughing
juhone
juhone
Post by juhone on Sun 12 Feb 2017, 9:03 pm
Nice. I've been eying that same chain too. It's expencive, but then again, it's goooold Very Happy
Post by Jameshambleton on Sun 12 Feb 2017, 9:20 pm
@juhone wrote:Nice. I've been eying that same chain too. It's expencive, but then again, it's goooold Very Happy
On my cb500 it was also a gold chain, looks very nice until the gold colouring comes off and it goes back to a silvery grey colour.
juhone
juhone
Post by juhone on Sun 12 Feb 2017, 9:27 pm
@Jameshambleton wrote:On my cb500 it was also a gold chain, looks very nice until the gold colouring comes off and it goes back to a silvery grey colour.
Oh, I didn't know they do that. What a bummer. I'll then have to reconsider my choice. Thanks for the info though!
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Sun 12 Feb 2017, 10:38 pm
They also go rusty quite quickly, even though they get oiled. my bike stood unused while I was in hospital, and I ended up with a rusty chain, rusty brake disc ( it's supposed to be stainless steel) plus I have a scot oiler fitted with the dual nozzles, so there should have been enough lube on the chain to stop corrosion
Post by Jameshambleton on Sun 12 Feb 2017, 10:46 pm
Depends how much you clean your chain and how much you use it I guess. Mine the color didn't last too long maybe 7 month but then again, it was a used chain and I average about 1.2K miles a month
@Crash- Elmit wrote:They also go rusty quite quickly, even though they get oiled. my bike stood unused while I was in hospital, and I ended up with a rusty chain, rusty brake disc ( it's supposed to be stainless steel) plus I have a scot oiler fitted with the dual nozzles, so there should have been enough lube on the chain to stop corrosion
I have a scottoiler fitted to mine and my chain never gets rusty... like ever. I have a single nozzle and I've left my chain for at least a month with no oil in the scottoiler (last month... oops) and never had an issue with rusting. My JT chain how ever is a completely different issue, it's basically made of rust at this point.
Crash- Elmit
Crash- Elmit
Post by Crash- Elmit on Sun 12 Feb 2017, 11:05 pm
The annoying thing is I bought the dearest chain/sprocket set, (DID O-ring gold chain) with a 525 code from M&P direct, because I thought it was the best quality one on their website.
Post by Jameshambleton on Sun 12 Feb 2017, 11:32 pm
@Crash- Elmit wrote:The annoying thing is I bought the dearest chain/sprocket set, (DID O-ring gold chain) with a 525 code from M&P direct, because I thought it was the best quality one on their website.
 Never buy from m&p, they're a bunch of clowns
Post by Jameshambleton on Sat 18 Feb 2017, 11:53 pm
New shiny things came today, so I thought I'd better do the right thing and fit them.
I had a look at the caliper and it has the pad retaining pin going into blind hole, before even attempting to remove them I got the blow torch and had contemplated drilling out the back of the caliper, but it wasn't needed. got the trusty plyers and out they came without any issues.
Two of the pistons started moving out first with the others remained strongly within their recesses. After some persuasion the others came out, I'll have to do some more tinkering with them soon
Post by Jameshambleton on Mon 03 Apr 2017, 10:24 pm
Suppose I'd better update this slightly, sadly my parts from Japan haven't come yet so not big updates.
I'm currently in the process of getting the DVLA to update the frame number on the V5c.
I managed to blow a hole in the petrol tank so I've had to order a replacement.
I've fitted a new front sprocket. I removed the engine cover and found that it had a crack/hole going all the way through it so that explains the oil on the floor either that or the brandit wanted to become a hardly movingson... though it's currently still sat there so who knows  Laughing
While changing over the pickup cover the screws that hold the pickup in place rounded with with my J.I.S screwdriver so I have to use the welder to try and get them both out...
Photo's will be added tomorrow at some point.
Post by sullivj on Tue 04 Apr 2017, 6:59 am
How did you blow a hole in the petrol tank?
Post by Jameshambleton on Tue 04 Apr 2017, 7:59 am
@sullivj wrote:How did you blow a hole in the petrol tank?
Airborne rust was coming out of it so I filled the tank with water and rinsed it out a couple of times. To then dry it out quickly I put the compressor on and stopped it at 2 bar and then I was blowing it round without an attachment on the air line so the air would be less directional and pop and out it came.
In all honesty I'm glad it happened when it did rather than when the tank is full of petrol and the engine been hot.
Project Bandit VVT 400 - Page 2 Y4mMPOaTkyq6vrjddGPfpFaOFi3i2tYYFtuOQbHvPZcjNXFq7y1P7gb510v81EywPHkkl3FiSNRWJGO8NjJzLJ3l1bx5FhTXK9HpCV7xCmtuxpjfBiHXtSqBkNSTM4HU5CbDJYvcIt7QIPnYBDRgVCTVFHcPQGwUUAl2iwRNEhnhyRLCnUKQDIsHlmbhjO3DRLk2_Pmg6YsoPRNG9VsCmyB-g?width=3096&height=4128&cropmode=none
Post by Jameshambleton on Fri 21 Apr 2017, 4:35 pm
FINALLY the much awaited package is in the uk
Project Bandit VVT 400 - Page 2 18056379_764350287072586_2964358543617495627_o
Post by skyrider on Fri 21 Apr 2017, 6:35 pm
a packet full of goodies Very Happy
Post by Jameshambleton on Tue 25 Apr 2017, 9:38 pm
@skyrider wrote:a packet full of goodies Very Happy
Very much so but it's a packet of goodies, that are now been held to ransom by ParcelForce!!!
They automatically pay the import duty on it and then charge you that cost + a handling fee just to rub the salt in the wound more... if you don't pay then they bin it  Mad
Post by skyrider on Wed 26 Apr 2017, 8:16 pm
that's very civil of them I don't think Mad
Post by Jameshambleton on Sat 29 Apr 2017, 8:25 am
@skyrider wrote:that's very civil of them I don't think Mad
Tuesday is the day of either disappointment or excitement
Post by Jameshambleton on Tue 02 May 2017, 9:40 am
Today is a bit of both, reservoir for the rear brake master cylinder has snapped..,  Everything else is fine!
Size of my helmet for perspective. Though half the box was in fact packaging.
Project Bandit VVT 400 - Page 2 Y4mlreA5VLVOxuvH_iG3zLI-2EJOmvXqYbOCOIVWSWquhs9BRUnIVdLKFVtLqZ0kW_HqyM4FNgfPkgv3JBaimOhXplFKRfTAu-PlxXs3G2WMbVJJDDaVyAEksbV5IO_Hq-zC07gP1kTU0XxlD_7phZOpS0EAMUxstCyoQW22d_4vf8zzVZsQaVEPLHsy5QKZyGyxgkL_VvgnM83LbnCDgZvhw?width=4128&height=3096&cropmode=none
And now the contents.
Project Bandit VVT 400 - Page 2 Y4m6LeecmgKv5jLPe5s8D6x_GWmNeD92tNYc1sR_qcL9OPjMBPfqCrDZMy8sY7h3XTNy57Jvpo9O0E-qr2kOswJScNWH8CoZs3vFixdl1TW7v27SRktiqNEd7lm51PRo0jPzu8XH_2xo4AobKHpifthSHGdh0kT63sfWg74Jw4dZI8RODtiKVdzPSJZl0xeM_pLcdBHDQnvf5Z-PSdPiQ9ijQ?width=4128&height=3096&cropmode=none
Post by Jameshambleton on Mon 14 Aug 2017, 9:56 pm
Right so I've been incredibly busy so I've got very little to update you all on. I finally found a starter/pickup cover gasket no less than genuine suzuki but their gaskets are so much better than Honda's. I had to order some new bolts to hold the pickup in place as the originals rounded themselves off so I had to use the welder on them.
With everything put back in its place and the pickup cover reattached I added petrol to the carbs and she eventually fired up.
I've fitted the new chain (thanks Andy) if you're wondering about the chain I previously wrote about that ended up going on my cb500 very very urgently.
Project Bandit VVT 400 - Page 2 Y4m4WVzH2uqR966mqPlRkdNdEhtKpPD_KU25_j5sKdyT5W9ecyXgS19HQ95FEZMdFYwZ8wr9XKfOuNNZd2Ijb1fC6a02GhZ7IslJKLd-3vA74Zi4MzhrekxAhYGjGbnwnKnZaS7Jz1iFUTPv7B5ilXT8wIWoke_SSvyJy31CWyELTjCsuj1FI2wnxUxcyyyk644lFxOvsXTc414Bj9Ry0kcjg?width=2322&height=4128&cropmode=none
[video] https://onedrive.live.com/embed?cid=A9633161BC82F8B3&resid=A9633161BC82F8B3%213384&authkey=AEBYjdJSo6DJSuM [/video]
Post by Jameshambleton on Thu 14 Dec 2017, 8:23 pm
Wow this project really did stall, taking the fork stanchions for getting straightened on Saturday. Really need to start pulling my finger out with this build.
    Current date/time is Mon 22 Jul 2019, 9:25 pm
