Problem to remove left cover (Stator) pls help
Crash_N_Burn
Post by Crash_N_Burn on Sat 08 Oct 2016, 11:38 pm
hi folks, im new to the forum. Im from Portugal a i am a honored owner of a CB500 95  Laughing with a 40k on it.
Recently ive felt in the flood and damage the left cover (the stator one).
I get a new one to replace it but i cant remove the center cap of the cover (Item Nº 6. CAP 30MM): (sorry i cannot post links)
Could you please tell me what orientation i need to do to the Alan 10´ tool?
Should i rotate it from left to rigth (like time in watchs) to open it, or the reverse?
Sorry my newbe but i strugle a day with it and i desperate already to open.
best regards folks and tanks for the possible help!
Re: Problem to remove left cover (Stator) pls help
Post by sullivj on Sun 09 Oct 2016, 1:43 am
They are often VERY difficult to remove. When I tried mine, I had the correct sized Allen key, and it just rounded out the hole.
It does turn anti clockwise (opposite of the clock!)
In the end, I hammered an old screw driver into the face of it, close to the edge, to move it in an anti clockwise direction.
Then i replaced it with a new one - they're not expensive.
Post by Jameshambleton on Sun 09 Oct 2016, 9:02 am
I've managed to round off and crack two of mine, might be worth using an impact driver is you have one.
Crash_N_Burn
Post by Crash_N_Burn on Sun 09 Oct 2016, 11:35 am
Tanks a lot folks for the answers!
I already managed to unscrew the Cap. Since the center was broken from own cover, it was dificult to me unscrew it with my hands, so decided to use a vise to hold the piece and then remove it. it was much more easier  Very Happy.
tanks ppl
Post by Jameshambleton on Sun 09 Oct 2016, 2:21 pm
Glad to hear you've got it sorted out, just got mine off by using a blow torch
Post by eternally_troubled on Wed 12 Oct 2016, 8:36 pm
@Jameshambleton wrote:Glad to hear you've got it sorted out, just got mine off by using a blow torch
Heat is always a good idea! That cover certainly doesn't come off easily...
    Current date/time is Fri 20 Jul 2018, 1:55 am
