Exhaust leak at cylinder head
Post by liverpool_f_ on Thu 29 Sep 2016, 8:00 pm
Hi all,
I hope this is an easy one. I recently installed a new exhaust and i think one of the pipes has not sealed properly. I think the tappety cylinder head noise is excessive. I did use the correct crush gaskets and i did torque it to spec.
Has anyone used exhaust sealant along with the gaskets? I don't think that it is supposed to be necessary but it may be a solution
Re: Exhaust leak at cylinder head
Post by sullivj on Thu 29 Sep 2016, 8:34 pm
I just used the gaskets, and it's been fine. Have you rechecked the torque in case they've worked loose?
Post by liverpool_f_ on Thu 29 Sep 2016, 9:11 pm
I did recheck it and it made no difference. 13nm seems like very little tension but thats what the book says
    Current date/time is Wed 21 Feb 2018, 11:33 am
