wheels
paul4very@aol.com
wheels
Post by paul4very@aol.com on Wed 14 Sep 2016, 6:10 pm
Hi dudes
Does anyone know if there is a straight forward swap from the standard alloys to wire whels?
Re: wheels
Post by liverpool_f_ on Wed 14 Sep 2016, 6:29 pm
I have never seen or heard of that for this model cb500 but I am sure it's not impossible. Probably more difficult than getting a wheel that fits is making the braking components fit correctly. Depending on how invested in the idea you are, you may want to consider swapping to a different braking system depending on what wheels you fit.
Re: wheels
Post by Beresford on Wed 14 Sep 2016, 6:54 pm
I can't think of any likely donor bike with a 17" front wheel, unless you can find something quite old and Japanese. Then they'd be manky, old, steel, and rusty !!
paul4very@aol.com
Re: wheels
Post by paul4very@aol.com on Wed 14 Sep 2016, 7:04 pm
Thanks guys
Will update when i succeed lol
Re: wheels
Post by trevor machine on Wed 14 Sep 2016, 7:32 pm
GB500? But the disc is on the near side.
Re: wheels
Post by Tricky. on Wed 14 Sep 2016, 7:38 pm
some motorcross bikes run 17" front wheels (called small wheel models), you could also use the forks and disc brake system complete. just make the cb triple clamp stem fit.
paul4very@aol.com
Re: wheels
Post by paul4very@aol.com on Wed 14 Sep 2016, 7:39 pm
May try forks and wheel change to save messing with brake setup !
Re: wheels
Post by eternally_troubled on Wed 14 Sep 2016, 10:51 pm
I'd certainly like to see the result of this if you succeed! Good luck finding some wheels/forks that fit!
Re: wheels
Post by Tricky. on Thu 15 Sep 2016, 8:13 pm
@paul4very@aol.com wrote:May try forks and wheel change to save messing with brake setup !
it will be easier to change the complete front end, unless you want to be making/machining caliper adapter plates, caliper spacers, inner wheel tubes, wheel spacers, wheel spindle, etc. changing the whole front end all youll have to do it get the steering stem to fit the new yokes.
Re: wheels
    Current date/time is Sun 24 Jun 2018, 7:38 pm
