Radiator
Radiator
Post by Jameshambleton on Thu 08 Sep 2016, 5:13 pm
Does anyone know of a compatible radiator for the cb5, I'm looking at a cbf500 rad but it has got completely different part numbers
Re: Radiator
Post by eternally_troubled on Thu 08 Sep 2016, 5:19 pm
I don't know of another one that this the same but I do know that the cbf500 one is different!
Were you trying to fix a hole in your radiator? It is possible to use that epoxy putty stuff - it won't work well (i.e. it might fall out) but, if you prep it well, it will stick and probably make your radiator leak proof. Snag is you have to find the hole...
Something like this: http://www.jbweld.com/products/waterweld-epoxy-putty
    Current date/time is Wed 17 Oct 2018, 8:07 am
