Help with a 2000 CB500
Mike246
Post by Mike246 on Thu 01 Sep 2016, 9:00 pm
Hi gents could you help please right here we go I have changed the battery and reficter after the bike would not charge the bits turned up today I fitted them took it out for a run it was ok
Now I decide to take it to work with me it was fine until it had a loss of power then it shut down could not be restarted but it sounded like the noise when the starter motor turning but not cranking pushed it half way home and I tried it it fired so I rode it home once I got home it shutdown again any ideas
Re: Help with a 2000 CB500
Post by Jameshambleton on Thu 01 Sep 2016, 9:45 pm
Check the coils/spark and the connectors to it, these can be easily found under the side stand side rad cowl. Check them for any corrosion.
Post by eternally_troubled on Fri 02 Sep 2016, 6:51 pm
Was the starter motor turning (whirring noise) but not engaging with the engine? Or was it just that the starter wasn't turning at all?
    Current date/time is Thu 26 Apr 2018, 12:45 am
