Cb500 Engine investigation
Cb500 Engine investigation  Empty Cb500 Engine investigation
Post by Jameshambleton on Wed 10 Aug 2016, 12:25 pm
Just the header and a tease of what's to come, as I'm writing this I have no idea either I've just eaten a crunchy nut butty for lunch.
Cb500 Engine investigation  13901564_627061537468129_5651763755615290290_n
Airbox side of the carb.
Airbox
Cb500 Engine investigation  13920667_627061534134796_8214236627863106834_n
Cb500 Engine investigation  Empty Re: Cb500 Engine investigation
Post by sullivj on Wed 10 Aug 2016, 12:51 pm
Nasty....
mcalvert39
mcalvert39
Post by mcalvert39 on Sat 13 Aug 2016, 10:04 am
Oh dear! Don't normally see things like this between the filter and the carb. My guess its spat it out from inside the engine. :/
Post by ANDYC on Sat 13 Aug 2016, 11:13 am
Is that the remains of your spark plug James?
Post by Jameshambleton on Tue 16 Aug 2016, 10:08 pm
Well I don't need to annotate any of these photos but I might do some anyway.
First thing out was the carbs and it wasn't looking well. This is metal hiding around my restrictor washer.
Cb500 Engine investigation  13882143_627255870782029_8349024097413037208_n
Little bit more metal in the carb worrying but at this point it might just be the sparkplug
Cb500 Engine investigation  13879291_627255877448695_2110664523298639022_n
Now I removed the carb and found this on the airbox side and I was becoming a little more worried.
Cb500 Engine investigation  13921148_627255927448690_7365832058879354570_n
Then I rubbed my finger around it and got this.
Cb500 Engine investigation  13912711_627255924115357_1971245032436349168_n
Next up was the removal of all this stuff. so photo of where the hoses go would be useful for reassembly
Cb500 Engine investigation  13912513_627255917448691_6010077413209677752_n
 With the carbs and airbox out of the way this is what I was left with.
Cb500 Engine investigation  13924929_627255980782018_8220507194212057352_n
I then had a look in the airbox and found this.
Cb500 Engine investigation  13892250_627255970782019_5019002801234928147_n
and these. so they'll have come out of the engine, through the carbs and back into the airbox.
Cb500 Engine investigation  13900337_627256024115347_5855572847952410568_n
Next up was the engine removal. I didn't get many photos from this point onwards but as you can see all the engine bolts are out as are the lower part of the frame.
Cb500 Engine investigation  13876567_627256030782013_4805868990602369612_n
After disconnecting everything as much as I could me and my mum got the engine out. We had the bike dropped into one side and we wriggled the engine about a bit until it came out. Never the less it's out!
Cb500 Engine investigation  13934788_627256047448678_7735236770193501720_n
Cb500 Engine investigation  13876319_627256090782007_2736999536199236_n
So after a uhh, crunchynut butty and 10w40 I was ready to go back to the bike.
Cb500 Engine investigation  13876469_627256097448673_7641523597184272622_n
Took the head off.
Cb500 Engine investigation  13882073_627256117448671_3186911825275831462_n
And as checked before the cams were in the right position and the cam chain and tensioner was good.
As I say I missed out a few steps so I lifted the engine up on my own and moved it about 12ft and 3ft in the air onto the work bench.
Cb500 Engine investigation  13934652_627256284115321_9060092576659747408_n
Next I slid off the bucket and found a cracked thing that the shim sits on. oh forgot I took the cams out too.  Rolling Eyes
Cb500 Engine investigation  13938553_627256344115315_7361859211690211076_n
After removing them all I started to remove the head.
Cb500 Engine investigation  13934646_627256414115308_5152100471054002982_n
After fighting with the head bolts for ages with my trusty stanchion breaker bar I got the head off.
Cb500 Engine investigation  13920663_627256410781975_802204099312811379_n
In the image on the left side you can see the remains of a valve.
Cb500 Engine investigation  13925179_627256500781966_5100046497973144507_n
After finding this I was a little annoyed putting it lightly... so I went up in my room and fiddled with the cb400's clocks.
Cb500 Engine investigation  13876568_627256510781965_2286720011359050788_n
Post by sullivj on Tue 16 Aug 2016, 10:23 pm
Nice write up James of a VERY sad day.. I feel your pain with every photograph.
One question... Crunchy nut sandwich... WTF is THAT all about?!
Total respect to your Mum for helping lift the engine out!
Post by Jameshambleton on Tue 16 Aug 2016, 10:24 pm
I had no breakfast and I needed some lunch but the fridge is literally empty so needs must.
Post by Jameshambleton on Wed 17 Aug 2016, 8:17 am
I forgot the photo of the piston so here it is and the bore is damaged at the top too.
Cb500 Engine investigation  13988142_630481723792777_4569555167308028592_o
Cb500 Engine investigation  14045579_630482273792722_5597532996910045954_n
It's very likely that I'll get getting another engine within the next 7 days just in time for college starting.
Post by eternally_troubled on Wed 24 Aug 2016, 3:34 pm
Wow. That is one cool sandwich. I might have to buy some crunchy nut cornflakes so I can try that out for myself.
That bit which had 'split' in half was a valve collet (spelling?) which stops the valves falling into the engine - it hadn't split in half, it usually comes in two pieces so you can assemble it around the valve stem while the spring is compressed, it is then held together once you release the spring back to its normal position by the metal bit on top of the spring (can't remember what that is called right now).
Are there any signs of why this happened? Did the one/both of the valve stems snap? Did the timing chain snap? Is it all so knackered you don't care? Smile Just wandering...
Post by Beresford on Wed 24 Aug 2016, 8:16 pm
Looking at all that, and thinking about the normal unburstability of the CB500, it even seems to resist attempts to over rev it.  I would guess that the timing chain slipped/jumped a cog tooth or two and the piston hit the valves a few times until the heads snapped off stopping play for the day.
Post by Jameshambleton on Thu 25 Aug 2016, 7:51 pm
Cam chain was the first suspect and it wasn't that, timings were spot on. It had indeed dropped a valve but I hadn't realised looking back, the only thing that I noticed a change in was that when it was idling it wouldn't fire on both pots, I gave it some revs and then it ran fine so I thought it was just some muck blocking the idle jet.
    Current date/time is Tue 17 Sep 2019, 7:26 am
