Clutch lever / free play spring
stelladragon
Post by stelladragon on Tue 09 Aug 2016, 5:31 pm
I've just changed the pressure plate springs, and fitted a lowish mileage basket which has reduced the rattle etc. Everythings fine, but the lever doesn't seem to spring back to the stop within the freeplay in the cable. Should it? I'm concerned I may not have the pushrod/spring quite right in the casing.
stelladragon
Re: Clutch lever / free play spring
Post by stelladragon on Tue 09 Aug 2016, 6:47 pm
With the clutch cable disconnected, the clutch arm springs towards the front of the bike. I can't recall what it was like before I took it to bits!
Post by eternally_troubled on Wed 24 Aug 2016, 2:15 pm
Did you manage to fix/adjust it? Not quite sure I've understood what you were going on about: the cable pulls the clutch arm towards the front of the bike when you pull the lever, it should sprint towards the back when you release...
    Current date/time is Sat 21 Apr 2018, 4:55 am
