Spec/stats
Spec/stats
Post by Jameshambleton on Fri 29 Jul 2016, 9:22 pm
Would it be possible to make this topic more detailed, such as what ebc pads are needed of the nissin and brembo calipers, details of how many links the chain is and what size the standard sprockets are and chain pitch, what sparkplugs are used ect what other sized tyres can be used.
Just generally make it more detailed and helpful.
Re: Spec/stats
Post by eternally_troubled on Sat 30 Jul 2016, 4:53 pm
Yeah, I'm sure it is possible. Those specs look a bit like they've been cut and paste from another website.
If you'd like to have a go at updating/re-writing them then go ahead - we can sort out where to put them once the content is sorted.
Re: Spec/stats
Post by ashcroc on Sat 30 Jul 2016, 6:16 pm
@eternally_troubled wrote:<<< snip >>>Those specs look a bit like they've been cut and paste from another website.<<< snip >>>
Everything in the 'Your CB' section was ported over from the old site when this one was created.
Re: Spec/stats
Post by Jameshambleton on Sat 30 Jul 2016, 6:47 pm
I'll write up what I can then, and then I'll post it here.
Re: Spec/stats
Post by Jameshambleton on Sat 30 Jul 2016, 9:46 pm
Unfinished at the moment just need to dump it so I don't lose it so far.
Honda CB 500
Years: 1994 - 2003
Engine and transmission
Displacement: 499.00 ccm
Engine type: DOHC Twin
Power: 57.00 HP (41.6 kW)
Torque: 46.00 Nm (4.7 kgf-m or 33.9 ft.lbs)
Bore x stroke: 73.0 x 59.6 mm (2.9 x 2.3 inches)
Gearbox: 6-speed
Transmission - Chain
Pitch:525
Links 108
Front sprocket: 15 teeth - JTF297
Rear sprocket: 40 teeth  - JTR1332
Physical measures
Dry weight: 173.0 kg
Seat height: 775 mm
Wet weight: 203kg
Chassis and dimensions
Front tyre : 110/80-17 120/70-17
Rear tyre : 130/80-17 130/70/17 140/70-17
Engine mounting bolts
Front: M10X260
Front with crash bars: M10X270
Upper rear: M10X165
Lower rear: M10X270
For replacement parts see Andy's thread http://www.cb500club.net/t4612-stainless-engine-mounting-bolts-and-alloy-spacers
Brakes
Front brake: Single 296mm disc 93-03
Rear brake: Single 240mm disc   97-03
Drum brake 94-96
Nissin master cylinder is able to be used with a brembo caliper, a brembo master cylinder is able to be used with a nissin caliper.
Note: The thread pitch is different on the banjos so make sure you get the correct one or you'll crossthread the threads
Brake pads
94-96 -  Nissin
Front: EBC FA196HH
Rear : EBC H321 - NEEDS CONFIRMATION!!!!
97-03 - Brembo
Front: EBC FA209/2HH
Rear: EBC FA213HH
Alternative direct fit brake calipers
Brembo 97-02 can be fitted to 94-96 models
Nissin 94-96 can be fitted to 97-02 - these are quite rare and expensive.
nt650v, right side is the exact same (including part numbers) brembo caliper as fitted to the 97-02 models. Cost about £35 on ebay
F2 cbr600 righthand caliper - personally not tested
Coolant
50% distilled/lime free (soft) water to 50% corrosion ethylene glycol
Alternative coolant
Evans waterless coolant - expensive but doesn't need to be changed  and doesn't need the expansion bottle
Spark plugs
NGK CR9EH-9
NGK CR8EH-9
electrode gap 0.8mm - 0.9mm
Carb Jet sizes
Pilot 38
main 122
Air filter
K&N HA-5094
Oil filter
Hiflo 303
K&N 303
Speed and acceleration
Power/Weight ratio: 0.3295 HP/kg
0-60: Around 4.5 seconds
Fuel tank
Fuel capacity: 18.00 litres (4.76 gallons)
Fuel reserve: 2.5 litres , personally I get 0.5 litres
Fuel hose: Inside 8 mm Outside 13 mm length 255 mm
Vacuum hose: Inside 3.5 mm Outside 8mm length 210mm - slightly longer maybe preferable
Forks
37mm - Note: stanchions sold by m&p are not compatible - ones sold by wemoto are
Fork seals dimensions 37x50x11mm
Handlebars
Renthal 759 bars fit with no alterations, 755 and 756's don't easily due to cabling issues
Suspension
Front forks
Standard oil 10w
hangon 7.5w
94 Spacer size, xxxmm, spring length 308.3mm, oil ml
96 Spacer size, xxxmm, spring length 509.9mm, oil ml
97 Spacer size 100mm, spring length 409.1mm, oil ml
98 Spacer size 100mm, spring length 409.1mm, oil ml
99 Spacer size 100mm, spring length 409.1mm, oil ml
00 Spacer size 100mm, spring length 409.1mm, oil ml
01 Spacer size 100mm, spring length 409.1mm, oil ml
02 Spacer size 100mm, spring length 409.1mm, oil ml
Note: spacer was measured from my pair of 97 forks and it shares that part number with years 97-02 so it **should** be the same length
Rear shocks
Hagon -
Tec - these are slightly longer than stock so when the bike is on the main stand both wheels stay on the ground. These are better than Hagon as they don't rust throughout winter riding.
Battery
ytx9-bs
Bulbs
Headlight h4 55w
Clocks -  naked model maybe different for the faired version? 12v 3w t10
Indicator bulbs need to be 21w for correct flash rate
tail light 12v 21/5w dual filament bulb
Sump plug
M14 x 1.5
Colour codes:
93 - 95
Tasmania green metallic   Code: G142
Black Code:NH 1
Seychelle nightblue Code: PB186
Fighting Red Code: R134
96
Black Code:NH 1
Procyon red metallic Code: R203
97
Black Code:NH 1
Titan metallic Code: YR183
98
Black Code:NH 1
Accurate Silver Code:NH146
Radiant red metallic Code:R218
Pearl citron yellow Code:Y140
99
Black Code:NH 1
Tango orange Code:YR201
00-02
Black Code:NH 1
Moodyblue metallic Code:PB296
Rich red metallic Code:R255
Credits: @Jameshambleton, @jerryfudd, @ANDYC, @muttley1
cb500-wiki.de, haynes manual
Last edited by Jameshambleton on Thu 25 Aug 2016, 3:00 pm; edited 10 times in total (Reason for editing : additional info added currently researching forks and brake calipers)
Re: Spec/stats
Post by Jameshambleton on Sun 31 Jul 2016, 11:11 am
If anyone can help confirm or give a bit more detail in some areas that I've done wrong or missed let me know
Re: Spec/stats
Post by ANDYC on Sun 31 Jul 2016, 12:50 pm
Headight bulb is a H4 fittment not H3
Re: Spec/stats
Post by Jameshambleton on Mon 01 Aug 2016, 7:40 pm
Since this thread is getting a lot of views, is there anything specifically that people are wanting to know or adding?
Re: Spec/stats
Post by muttley1 on Mon 01 Aug 2016, 9:03 pm
and as most bikes will need some hard-to-find spares in due course this is a top thread imo, I'd like info on:
nissin/brembo master cyl and caliper combos / internal diameters
compatability with other Honda models for front calipers - F2 cbr600 righthand ones fit, I think F3, deauville and mid 90's vfr and Hornet ones do too (needs confirming)
I think the Nissin master cylinders were only fitted up to 1996 (needs confirming), important if you are ordering a master cylinder repair kit. Nissin and Brembo internals are totally different here.
revs for peak torque
and to add that Renthal 759 bars fit with no alterations, 755 and 756's don't easily due to cabling issues (although cabling can be re-routed) and clip ons don't work as no space for master cylinder. They're not allowed in Thundersport either.
Tec shocks are very good value replacements and work well. Hagon are more expensive but you can speak to them to get a spring rate relative to your weight and the roads you ride.
Progressive Hagon springs for the front come with oil (7.5w) but when fitting, the tighter coils of the spring are to be fitted at the top, not at the bottom of the forks like the stock ones.
Re: Spec/stats
Post by Jameshambleton on Mon 01 Aug 2016, 9:11 pm
@muttley1 wrote:Hi,
Oh my  Shocked Some of that info I actually needed myself but had forgotten. I'll get this researched asap!
Re: Spec/stats
Post by Beresford on Tue 02 Aug 2016, 4:52 pm
The Nissin master cylinder is used on a vast range of bikes - including Triumphs and Buells for example. As far as I can find out the bores are available in sizes  1/2" , 14mm , 5/8" and maybe others in between. I have seen them frequently on offer on ebay complete with an adjustable lever (normally fitted to Tiger 800s in 14mm bore size). The 5/8" is used on older Trophys, Daytonas and the new Explorer range.
The only Triumph I know of that uses the 1/2" cylinder is the 955i Tiger, but this results in a soft lever feel with the twin calipers on that bike.
Anybody know the bore of the Nissin cylinder on the CB500 ?
I see on the Wemoto site that Nissin rebuild kits are much cheaper than the Brembo ones.
Re: Spec/stats
Post by Jameshambleton on Tue 02 Aug 2016, 8:25 pm
@Beresford wrote:The Nissin master cylinder is used on a vast range of bikes - including Triumphs and Buells for example. As far as I can find out the bores are available in sizes  1/2" , 14mm , 5/8" and maybe others in between. I have seen them frequently on offer on ebay complete with an adjustable lever (normally fitted to Tiger 800s in 14mm bore size). The 5/8" is used on older Trophys, Daytonas and the new Explorer range.
I don't understand most of that but I can say that the inner diameter of the main cylinder should be 11.000 to 11.043 mm and the wear limit is 11.055 mm. The outer diameter of the master cylinder piston is 10.957 to 10.984 mm and the wear limit is 10.945 mm. But as I say that's just words and numbers to me  scratch
Re: Spec/stats
Post by Beresford on Tue 02 Aug 2016, 8:55 pm
Well the 1/2" Nissin cylinder would be 12.7mm bore so would give the CB which has an 11mm cylinder, a firmer lever feeling. Maybe better for trackday use.
Re: Spec/stats
Post by ashcroc on Thu 25 Aug 2016, 3:33 pm
CB400 super four right side brake caliper & bracket is identical to 94-96 nissin just gold instead of silver.
Re: Spec/stats
Post by Jameshambleton on Thu 25 Aug 2016, 4:47 pm
@ashcroc wrote:CB400  super four right side brake caliper & bracket is identical to 94-96 nissin just gold instead of silver.
I was actually going to try this myself, as the front end of the cb400sf nc31 looks the same as a cbr600 f3.
Re: Spec/stats
Post by Jameshambleton on Mon 24 Apr 2017, 10:19 am
Bearing sizes
Front wheel (all models)
Bearing size
x2 6302uu
Disc side seal 22x42x7
speedo drive side 40x50x5
Rear wheel
Disc models
x2 6303uu
Sprocket
6304uu
Seals
Disc side 28x47x7mm
Sprocket carrier 30x52x7mm This is only for the 1998 models onwards and not the 1997
NOTE: THERE IS A SPROCKET CARRIER YEAR OVERLAP ON THE 1997 MODELS.
The 1997 uses a 6204 sprocket carrier bearing and a 28x47x7mm dust seal.
Drum models
x2 6303uu
Sprocket
6204uu
Seals
Drum side N/A
Sprocket carrier 28x47x7mm
Last edited by Jameshambleton on Mon 15 May 2017, 4:00 pm; edited 2 times in total
Re: Spec/stats
Post by jchesshyre on Tue 25 Apr 2017, 12:47 pm
34.7 lb ft / 47 Nm @ 8000 rpm
Re: Spec/stats
    Current date/time is Sat 16 Feb 2019, 3:20 am
