Engine
Solved Engine
Post by Jameshambleton on Mon 25 Jul 2016, 6:47 pm
Wanted cb500 engine in working order.  The closer location to Bedale, North Yorkshire or Hull, East Yorkshire the better!
Solved Re: Engine
Post by Tricky. on Mon 25 Jul 2016, 6:52 pm
what exactly has happened to yours?
Solved Re: Engine
Post by Tricky. on Mon 25 Jul 2016, 6:57 pm
two in sheffield.
http://www.ebay.co.uk/itm/Honda-CB-500-Engine-/322182314106?hash=item4b038ff87a:g:osAAAOSwXeJXe7Xa
http://www.ebay.co.uk/itm/honda-cb500-engine-/322182315380?hash=item4b038ffd74:g:U3UAAOSwuzRXe7bN
Solved Re: Engine
Post by Jameshambleton on Mon 25 Jul 2016, 7:38 pm
I've already checked ebay, just seeing if anyone on here had one spare... as you do... The electrode of the sparkplug and most of the thread has disappeared and the rest is inside of the plug and presumably the engine too. So the piston will be fucked as well the valves and the head. Oh well I guess I'll have some shims to donate to the form shim collection ect
Solved Re: Engine
Post by sullivj on Mon 25 Jul 2016, 8:09 pm
Shims are always welcome in the exchange James, but sorry to hear about your engine.
Llewelyn1965
Solved Re: Engine
Post by Llewelyn1965 on Mon 25 Jul 2016, 11:52 pm
@Tricky. wrote:two in sheffield.
Are these good prices for an engine?
Solved Re: Engine
Post by ANDYC on Tue 26 Jul 2016, 7:40 am
They're good prices if the engines are good. Sadly experience has taught me that you get what you pay for in these situations. If you have the ability to rebuild yours then it would be the best option, in a cost/benefit way of looking at it.
Solved Re: Engine
Post by Jameshambleton on Tue 26 Jul 2016, 9:13 am
I'm going to get an engine from boonstra parts as it's about £180 POSTED!!!  cheers I'm going to run this to keep the bike on the road, I know they're missing some parts but I think all should be well and good since I have a couple of now dead engines to borrow things off.
I'm going to rebuild my engine depending upon if the bore is damaged and then I'll go from there.
Solved Re: Engine
Post by eternally_troubled on Tue 26 Jul 2016, 11:07 pm
You can't really argue with 180 quid inc postage from Holland! Assuming it works Wink
If you ever get to take the old one apart I'd be interested to see the photos from inside!
Solved Re: Engine
Post by Jameshambleton on Tue 26 Jul 2016, 11:41 pm
@eternally_troubled wrote:You can't really argue with 180 quid inc postage from Holland!  Assuming it works Wink
You know, the garage that I take the bike to for things that are too out of my depth have said the same thing, they're really interested in what it looks like inside the same as me. I might video it and put it on the tinterwebs
Alvi
Solved Re: Engine
Post by Alvi on Wed 27 Jul 2016, 9:52 pm
Many years ago, a nut dropped out of the k&n filter, straight through the weber & manifold into my Capri combustion chamber - made a hell of a racket as it rattled between piston & cylinder head. I figured the only option was a full rebuild & took the engine out. When I took the head off, I found the nut had welded itself to the piston crown & it probably would have run happily for another 50,000 miles. Still, now I'd started, I might as well go for an overbore, high lift cam & rejetted weber.......Wink
Solved Re: Engine
    Current date/time is Mon 28 May 2018, 2:32 am
