Clip Ons
ratatooie
ratatooie
Clip Ons
Post by ratatooie on Mon 18 Jul 2016, 12:04 pm
Am I right in saying that the CB would take a set of 37mm clip ons?
Does anyone have any recommendations for some half decent ones to use, or should I just head to ebay for some generic ones?
Re: Clip Ons
Post by ashcroc on Mon 18 Jul 2016, 12:27 pm
37mm will fit the forks.
@mutley1 tried a set from a VFR400 a while back but had problems with fitting the m/c.
Not sure that'd be a problem with the trees & clocks you're running but it's worth taking into consideration.
Worst case something like a r6 front m/c with it's separate fluid reservoir could be an option.
Re: Clip Ons
Post by Beresford on Mon 18 Jul 2016, 12:34 pm
Here you are cheers
http://www.ebay.co.uk/itm/Universal-clipon-clip-ons-handlebars-30mm-to-36mm-used-but-in-fair-condition-/252457649423
ratatooie
ratatooie
Re: Clip Ons
Post by ratatooie on Mon 18 Jul 2016, 2:52 pm
Ah I hadn't seen that thread cheers.
A lot of the work to be able to use clip ons seems to have been done already (instrument cluster and fabbed top yoke), which is good, but the clip ons themselves are horrible and I am not sure that I could salvage them. I had in my mind something like these, which have the advantage of being adjustable in pitch too:
http://www.ebay.co.uk/itm/252026039097?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
@Beresford wrote:Here you are cheers
Hah! Those are quite something aren't they. I don't think I have ever seen anything like them!
Re: Clip Ons
Post by muttley1 on Tue 19 Jul 2016, 12:45 pm
and nope, clip ons aren't a success on the cb5, for that cafe racer individual look go for jota bars. Depending where you drill for the switchgear you can adjust the width of the grips and the things allow you to mess with the riding position endlessly.
If you go the clip on look you'll need rearsets and a longer gear lever, and to adjust the brake light switch too.
I gave in in the end and renthal 789 ultra lows with little bar end mirrors look and work fine.
atb
btw the Tec shock folks do jotas for £55 iirc, much cheaper than Busters etc. Also, Basil Moss has ace bars on his, think he gets on well with them.
Re: Clip Ons
Post by Beresford on Tue 19 Jul 2016, 1:27 pm
Muttley, have you ever seen a set of the TEC Jotas? I was considering them for another bike, and wondered what the quality was like?
Re: Clip Ons
Post by muttley1 on Tue 19 Jul 2016, 2:07 pm
nope, saw them on the products-available list Tec sent with my new shocks. Looked ok.
ratatooie
ratatooie
Re: Clip Ons
Post by ratatooie on Tue 19 Jul 2016, 5:30 pm
Great thank you for the info. Very much helpful. Those Jota Bars look great and are basically what I would have been paying for the fleabay clip on jobs. Are they just pretty much plug and play? I'm at the point of ordering some TEC shocks anyway so it might be an idea to add those bars to the order! Have to wait until payday though...
Re: Clip Ons
Post by Beresford on Tue 19 Jul 2016, 9:12 pm
If you do get them (the Jotas) post your impressions here, please. I've been wondering what they're like since my wrists started to complain after an hour or so on the bike when the hand grips are not quite at the right angle !!
Re: Clip Ons
Post by muttley1 on Tue 19 Jul 2016, 10:04 pm
HI,
yep, jota bars are easy to set up. Work out where you want them, make sure the cabling runs freely, drill for the switchgear and alls good.
I've had them on one bike, no issues at all. They got around the stock bars/master cylinder catching on a powerbronze fairing iirc.
Re: Clip Ons
    Current date/time is Sun 24 Mar 2019, 7:02 pm
