side panel
side panel
Post by skyrider on Sat 18 Jun 2016, 8:05 pm
I have a left hand side panel (fuel lever side) up for grabs in plain black in reasonable nick still with the lugs, it came with the bike when i got it, I also have the right hand side one as well but that is well ropey, anyway if anyone is in need of a half decent left panel let me know Smile
Llewelyn1965
Llewelyn1965
Re: side panel
Post by Llewelyn1965 on Sat 18 Jun 2016, 8:46 pm
I have 2 bikes, well 1 and a half now I've robbed the good bits from one to use on the other, and on both bikes, the left panel is good and the right one has problems with the lug. I think this might be a trend!! :-(
Re: side panel
Post by skyrider on Sat 18 Jun 2016, 8:52 pm
yes I think you could be right there is a hole on mine where the lug used to be Smile
Llewelyn1965
Llewelyn1965
Re: side panel
Post by Llewelyn1965 on Sat 18 Jun 2016, 9:03 pm
I think when I get the opportunity I might drill out the slot the lug goes into. Just by a tiny bit.
Re: side panel
Post by skyrider on Sat 18 Jun 2016, 9:12 pm
both the lugs have disappeared on mine the round and the square, so see what happens someone might be able to plastic weld some lugs on
Re: side panel
Post by ashcroc on Sat 18 Jun 2016, 10:59 pm
I've got one from an old bike that had the lug replaced by a screw head bolt. It wasn't pretty as it showed through to the outside but it worked.
Re: side panel
Post by skyrider on Sun 19 Jun 2016, 5:24 pm
that's it as long as it works that is the main thing
Re: side panel
Post by skyrider on Fri 22 Dec 2017, 10:20 am
@skyrider wrote:I have a left hand side panel (fuel lever side) up for grabs in plain black in reasonable nick still with the lugs, it came with the bike when i got it, I also have the right hand side one as well but that is well ropey, anyway if anyone is in need of a half decent left panel let me know Smile
the left panel is still available if anyone is interested santa
Fair Weather Rider
Fair Weather Rider
Re: side panel
Post by Fair Weather Rider on Fri 22 Dec 2017, 12:55 pm
If you slip a long screwdriver behind the panels at the bottom of the tank and just put a bit of pressure (Gently does it) on the back side of the panel, they come out quite easily, also grease the lugs when you put them back on. Very Happy
Re: side panel
Post by eternally_troubled on Mon 25 Dec 2017, 11:07 am
Yes, grease the lugs. I have cracked my panel by pulling it too much - a little lubricant would have made everything easier (applies to many situations!)
Re: side panel
Post by skyrider on Mon 25 Dec 2017, 11:22 am
well the ropey panel went in the bin a few months a go and seeing as I don't have the bike anymore the decent panel is available Smile
Re: side panel
    Current date/time is Sat 23 Feb 2019, 2:14 am
