Master Cylinder Trouble
supersim65
Post by supersim65 on Tue 07 Jun 2016, 12:06 pm
Hi, I'm new to the forum and I'm an idiot.
I got over-zealous last night and I think I've messed up the Brembo master cylinder on my nice new 1998 CB500S.
I couldn't see the level inside the window, so I thought 'hmm, I'll just pop that open and see if it's under/over-filled.' One screw came out fine, and I put is somewhere safe. The other was a bit sticky, and snapped in half en-route out of the hole. Just the head came out.
So I grabbed the drill, had a go at drilling the second half out, and inadvertently went a bit sideways. I have unexpectedly good drill bits these days. To top it all off, I couldn't for life of me remember where the safe place I put the good screw was. So that's gone too.
So three questions I would appreciate some help with...
1. How unsafe is my newly cable-tied master cylinder cap?
2. Does anyone think I might be able to tap a wider thread into the knackered screw hole? Or am I on the hunt for a new master cylinder?
3. Does anyone have a spare Brembo front master cylinder?
P.S. It was very slightly over-filled by the way. So there really was no need for any of this to happen. Mad
Anigai
Re: Master Cylinder Trouble
Post by Anigai on Tue 07 Jun 2016, 3:01 pm
1st welcome to the forum.
To answer your questions.
1. Personally I wouldn't worry about it too much but then again I'd use a few cable ties more than your average Joe Bodger.
2. There are a couple of mm spare on the stock cylinder caps and it is only aluminium. Be very careful though but I don't think I really need to mention that.
3. I have a turkey baster somewhere you could hook up to the brake line if it's any use? Smile Smile Smile
Post by muttley1 on Tue 07 Jun 2016, 4:03 pm
Hello and welcome along.
You can get replacement master cylinders on fleabay for £15 or so iirc. Tempted by one myself as the master cylinder overhaul kit is a fair bit more than this.
atb
supersim65
Post by supersim65 on Tue 07 Jun 2016, 5:22 pm
Has anyone tried those FleaBay master cylinders? £15 for a part that's £200 from Honda on my front brake sounds like a cheap way to die.
Could always use it for basting a turkey though.
I think I'll stick to cable ties, and wait around for an eBay find. Better stick a wanted ad up.
Post by eternally_troubled on Fri 17 Jun 2016, 10:00 am
Wait until a good second-hand one comes up on ebay - you can also buy an overhaul kit if you want.
It is certainly possible to fix the screw-problem, but it does required a bit of mechanical ability/stupidity and a tap and/or helicoil kit.
    Current date/time is Sun 18 Feb 2018, 5:01 am
