refitting tank
refitting tank
Post by skyrider on Wed 11 May 2016, 7:12 pm
weather was crap again this morning so I refitted the tank everything went ok  but why don't Honda make their fuel lines a bit longer it would make things a lot easier Rolling Eyes
Re: refitting tank
Post by sullivj on Wed 11 May 2016, 8:25 pm
If it's the overflows that are a bit tight, you can pull them up a bit.
Re: refitting tank
Post by skyrider on Wed 11 May 2016, 9:51 pm
yes I think I have cracked it now, its just the two throttle altering screws under the tank that's worrying me a bit now one for opening and the other for pulling the throttle closed I altered one of them when I was oiling the cables I just hope I haven't buggered up the settings and have to take the tank off again still I will only find out when I fire the bike up
Re: refitting tank
Post by sullivj on Wed 11 May 2016, 10:18 pm
I think they're accessible with the tank on, with the right carb adjustment screwdriver..
Like this:
http://www.ebay.co.uk/itm/Motorcycle-90-deg-Angle-Driver-Carb-Tool-Boxed-Screwdriver-Set-/131313508732?hash=item1e92e5217c:g:tnIAAOSw1x1UL8vl
Re: refitting tank
Post by Tricky. on Thu 12 May 2016, 7:37 pm
ive got rid of the overflow pipes, and replaced the fuel and vac pipes with longer ones.
Re: refitting tank
Post by skyrider on Thu 12 May 2016, 7:45 pm
it would have been a good idea if Honda had done that in the first place if you just lift the tank up a bit the pipes pop off, anyway as said its just the throttle screws now and see what happens
Re: refitting tank
    Current date/time is Sun 24 Jun 2018, 11:59 am
