Bt45 tyre pressures
Bt45 tyre pressures
Post by wornsprokets on Sun 24 Apr 2016, 11:49 pm
I have new bt 45 tyres front and back ive about 900 or so miles on them, ive followed the tyre pressures recommended on the tyre wall, ive noticed cracks in the crown of the  front tire w.t.f, what tyres pressures are recommended for bt45 you use?
Basil Moss
Re: Bt45 tyre pressures
Post by Basil Moss on Mon 25 Apr 2016, 6:14 am
33 front, 40 back.
hh_12345
Post by hh_12345 on Mon 25 Apr 2016, 9:24 am
2.5/2.8 and 2.5/3.0 are recommended on the german cb 500 wiki
http://www.cb500-wiki.de/doku.php?id=fahrwerk_und_rahmen:reifen&s[]=reifen
Post by liverpool_f_ on Mon 25 Apr 2016, 10:27 am
Honda and Bridgestone have different recommendations for BT45. Neither should cause any damage to the tyre though. I can only suggest taking it back to the tyre place and say that you think it is defective. Maybe it was really old from laying around in a warehouse somewhere for ages.
Post by Jameshambleton on Mon 25 Apr 2016, 10:56 am
What DOT date is your tyre?
Post by Jameshambleton on Mon 25 Apr 2016, 11:20 am
@hh_12345 wrote:2.5/2.8 and 2.5/3.0 are recommended on the german cb 500 wiki
The one page of the wiki I've never bothered to read but one of the most helpful, Thanks!
Post by Guest on Mon 25 Apr 2016, 2:56 pm
I do 29 - 36 as that is what the sticker on the chain guard says. Mine are BT45's.
Post by eternally_troubled on Mon 25 Apr 2016, 3:52 pm
@wornsprokets wrote:ive followed the tyre pressures recommended on the tyre wall....
Usually the pressures written on the sides of the tyres are the maximum pressures and loads - not usually what you want.  What pressures have you been using?
The ones that Basil posted earlier look like the ones that Bridgestone recommend (which are a little higher than the 'original' pressures for the bike that are written on the chainguard) - probably the best thing to use.
Post by teamster1975 on Mon 25 Apr 2016, 6:16 pm
36 front, 40 rear (I picked that up on here some time back, here's the link.)
Post by badseeds on Sun 01 May 2016, 8:44 am
I run 36/42 PSI on all tyres on all bikes, but I consider myself a tyre/suspension cretin; I just ride.
Post by wornsprokets on Sun 01 May 2016, 12:35 pm
Sorry for late reply my bt45s are from 2015
Post by skyrider on Sun 01 May 2016, 4:04 pm
recent rubber then Smile
Post by trevor machine on Mon 02 May 2016, 8:10 am
i've got dem michelin pilot activs on and they definitely don't feel right at 29 & 33.
    Current date/time is Mon 22 Jan 2018, 12:33 am
