Replacement bits following a little off
Factoryrsvr
Factoryrsvr
Replacement bits following a little off Empty Replacement bits following a little off
Post by Factoryrsvr on Sat 23 Apr 2016, 10:37 am
Would be grateful if anyone could point me in the right direction of the following to help me put my red CB500S - R plate I would be very grateful:
  • Right-hand side fairing or whole fairing
  • Handle bars, forks , levers, clocks, reservoirs etc are all ok somehow.
  • Right hand indicator
  • Foot brake lever
Considering the speed we went down, it crashed very well and started first time when I got it back on its wheels. Any help ontrackingn these parts down would be gratefully appreciated.
Replacement bits following a little off Empty Re: Replacement bits following a little off
Post by ANDYC on Sat 23 Apr 2016, 6:34 pm
I can help with a rear brake lever, £10 posted.
 I may have an indicator too, I'll check on that tomorrow.
Factoryrsvr
Factoryrsvr
Post by Factoryrsvr on Sat 23 Apr 2016, 8:24 pm
Cheers. I managed to bend the brake lever back into shape in a vice  Laughing Looks like I just need one side of fairing. Has anyone ever replaced the handlebars? Is it as simple as unbolting everything and putting it all back on the new ones?
Alvi
Alvi
Post by Alvi on Sat 23 Apr 2016, 9:20 pm
You'll be lucky to get the left grip off without slicing it. The cables & wiring don't have enough slack for the switch & lever assemblies to slide off while the handlebars are still bolted on, you'll have to unbolt them & move them from one side to the other while you slide each side off (depends how bent your bars are, I suppose Wink). If you fit pattern bars, you'll probably 'lose' the locating holes for the switches, so you'll either have to drill some, or cut the locating pips off the switches & make sure the screws are really tight. Can't think of anything alse, but maybe someone else can?
hh_12345
hh_12345
Post by hh_12345 on Sun 24 Apr 2016, 10:14 am
I have easily removed grips with a screwdriver and spraying degreaser,
the way it is shown in this video:
If you go for an aluminum bars and drill holes in them do not measure the holes location from the steel bars. If you do so the throttle grip will stick out  and you might have trouble fitting bar ends, as the original ones do not fit the smaller aluminum bar internal diameter and many bar ends for alloy bars do not allow overlapping  with the throttle tube.
The_Wasp
The_Wasp
Post by The_Wasp on Sun 15 May 2016, 1:41 pm
If you're still looking I've got a set of clocks available, handlebars and some fairing pieces if they're any good to you.
Post by Tricky. on Sun 15 May 2016, 6:51 pm
i also have some rear fairing bits available if Wasp doesnt have what you need.
    Current date/time is Mon 20 May 2019, 8:34 am
