Ignition wiring
tsteverton
Ignition wiring
Post by tsteverton on Fri 01 Apr 2016, 12:25 pm
Hopefully someone can help here,I have a cb500 1995 and about a month ago,some dickheads decided to take it for walkies...to cut a long story short,I need to get to the underside of the ignition barrel...i'm not changing it,just soldering properly (as the job that was already done was a temporary repair to get me to work)the wires back in.Now,It looks like I only have to remove the top yoke and the ignition comes off with it,as i'm still keeping the same ignition,i dont need to remove the Torx bolts do I ,looked at the manual but to be honest ,It makes you go around the houses to do the job. Any help please !!
Re: Ignition wiring
Post by ashcroc on Sat 02 Apr 2016, 1:04 pm
The ignition will come off with the top yoke as you thought. Whether you'll be able to play around with it without removing them from the yoke I have no idea.
    Current date/time is Wed 23 May 2018, 11:58 am
