Rear brake caliper parts
arrison
Post by arrison on Mon 21 Mar 2016, 8:35 pm
Looking for a part for my rear brake caliper, as it looks like mine is slightly bent. Trouble is, none of the websites with exploded diagrams on have any info on the bit I want. So, does anyone know:
A - what the part with the red ring about it is called, and
B - where I can get hold of one?
Re: Rear brake caliper parts
Post by Jameshambleton on Mon 21 Mar 2016, 9:08 pm
A. sliding pin
B. dunno
Post by Beresford on Mon 21 Mar 2016, 9:22 pm
I'm guessing on the size, but I think those pins are 6mm. So get a stainless steel bolt on ebay and cut the head off, and maybe shorten the threaded section to suit as well. That'll do the job. For about 10p.
Stooby2
Post by Stooby2 on Tue 22 Mar 2016, 6:52 pm
That's one of the pins the caliper slides on and is protected by a rubber boot. I dont think a bolt will do it and could damage the socket the pin slides into.
You could try emailing David Silver spares. Or see if you can get another caliper on eBay.
Post by sullivj on Tue 22 Mar 2016, 7:20 pm
I don't think it's supplied separately. You could have one machined up, but it would be cheaper to get a second hand caliper with one attached.
I'm not sure how easy it is to unattach it from the caliper though?
Stooby2
Post by Stooby2 on Wed 23 Mar 2016, 6:51 pm
They simply unscrew - the end has an allen key fitting.
davebike500
Post by davebike500 on Thu 24 Mar 2016, 9:21 am
Neither of the sliding pins are separate parts either from Honda or BMW that uses the same calliper (OK mirror image)
If anyone can find some I be very interested as I had to buy used callipers to sort bikes
arrison
Post by arrison on Thu 24 Mar 2016, 7:13 pm
A second hand caliper on ebay is going for around 40 quid. Id have rather paid a tenner or so for the pin than that, but if theyre not available as spares then looks like thats the only option
Post by Beresford on Thu 24 Mar 2016, 7:45 pm
You have to hope that the pins on those aren't knackered as well.
Post by skyrider on Thu 24 Mar 2016, 7:55 pm
and if they are you are in the same boat BUY NEW ONES if possible
    Current date/time is Sat 21 Apr 2018, 8:47 am
