Handlebar shake
Handlebar shake
Post by Jameshambleton on Sun 13 Mar 2016, 8:05 am
I had my front wheel balanced and it's balanced as when I have put the bike on the main stand, removed my front caliper and I can place the wheel in any direction and it will stay still.
When I'm riding along if I let go of my handlebars they shake to the point of almost tank slapping, does anyone have any suggestions on what could be causing it?
Re: Handlebar shake
Post by Tricky. on Sun 13 Mar 2016, 10:17 am
uneven fork oil/leak, caliper dragging/disc warped, tyre pressure, tyre condition, head bearings, triple clamps tight. issues with the rear can also affect the front, tyre pressure, shocks tight, swingarm bolt.
jim157
Re: Handlebar shake
Post by jim157 on Sun 13 Mar 2016, 10:52 am
Top boxes can also exaggerate these problems.
Re: Handlebar shake
Post by wornsprokets on Sun 13 Mar 2016, 11:57 am
Could it be  front wheel bearings  or  headrace bearings(loose or warn)
Stooby2
Re: Handlebar shake
Post by Stooby2 on Sun 13 Mar 2016, 1:29 pm
This may be a bit radical, but can I suggest not letting go of the handlebars?
Re: Handlebar shake
Post by sullivj on Sun 13 Mar 2016, 1:39 pm
Mine do the same, and I've not yet been able to find out why.
Re: Handlebar shake
Post by ANDYC on Sun 13 Mar 2016, 3:59 pm
If you have a top box fitted this will happen regardless of everything else being spot on.
I just keep hold of the bars Very Happy
Re: Handlebar shake
Post by Jameshambleton on Tue 15 Mar 2016, 4:38 pm
Little update, if I let go of the bars when I'm doing 70 and 80 and even 90 (km of course) then there is no handlebar shake, anything under these speeds and it shakes really violently
Re: Handlebar shake
Post by muttley1 on Tue 15 Mar 2016, 4:45 pm
This came up ages ago. From experience worn tyres (esp rear) don't help and as said, topboxes aren't great for stability either.
Most bikes have a little shake at 30 odd as the gyroscopic effect of the wheels kicks in, at faster speeds then tyres/topbox, assuming tyre pressures are ok.
Re: Handlebar shake
Post by Beresford on Wed 16 Mar 2016, 9:51 pm
Here's some good info.
Re: Handlebar shake
    Current date/time is Wed 23 May 2018, 11:54 am
