Headstock Bearing Replacement Video
Post by jerryfudd on Sat 12 Mar 2016, 8:52 am
As I'm sure many of you do I watch the Delboy videos with great interest so was pretty keen to watch the near universal headstock bearing removal video on his Ninja 750 after having such an absolute nightmare doing it on the CB so was hoping to pick up some tips... even more so when I saw the Allballs packet as thats what I put in.
Let me just say on a CB (as many of you know) its not that easy... not even close which has frustrated me even more than having to do it Neutral
Not only is there a lip on the cup to get a purchase on but at Kawa they actually had the forethought to put a notch in the headstock to make the lip even bigger at two points either side to aid knocking it out - something you don't get on the CB.
I'm just annoyed that it can be so straight forward on some bikes but not on the CB Crying or Very sad
As he says, instead of re-greasing he just slaps in a new one and if it was that simple so would I Smile
EDIT: some links of members pains and triumphs if you want to do it on your CB
http://www.cb500club.net/t2761-headstock-bearing-replacement
http://www.cb500club.net/t562-headstock-bearings-help
http://www.cb500club.net/t2461-advice-fitting-new-steering-head-bearing
Re: Headstock Bearing Replacement Video
Post by wornsprokets on Sun 13 Mar 2016, 1:00 pm
Any pics of process of doing cb headraces, my bike seems fine headrace wise, but it wouldnt surprise me if mine are original, my bike was left up for about 5 yrs before i bought it it wasnt a daily commuter ridden every day has 34k miles on it. Are all balls bearings good, do wemoto sell them
Post by jerryfudd on Sun 13 Mar 2016, 4:39 pm
the stock ones work well enough so if the cups are good you could just get away with re-packing the current setup with grease or replacing the caged bearing. I went with an Allballs tapered roller bearing kit from wemoto. They apparently last longer and harder to fudge up when it comes to overtightening.
    Current date/time is Fri 25 May 2018, 2:17 am
