Which switch? Bike won't start when in gear.
Post by Beresford on Sat 27 Feb 2016, 6:46 pm
I was out for a run today to look at the Groms on show in Belfast Honda, and hit a problem. The bike stopped at a traffic light and I found that there was no go when I pressed the starter button. The bike was in gear and I had the clutch lever pulled in but nothing. The ignition light was on OK but the bike was dead until I put it into neutral and then it started OK. The neutral light worked OK, and when I got home I checked that the side stand cut-out was working OK as well.
Any suggestions as to what this problem might be caused by ?
Re: Which switch? Bike won't start when in gear.
Post by wornsprokets on Sat 27 Feb 2016, 6:58 pm
Was your lights on when it cut out, my fireblade cut out with lights on it was starting of regulator rectifier going bad. I had corrosion in starter switch and ignition too
Post by jerryfudd on Sat 27 Feb 2016, 7:07 pm
sounds like the bike didn't know the clutch was engaged..... can't recall what electronic gubbins sense that.
Post by jerryfudd on Sat 27 Feb 2016, 7:15 pm
@jerryfudd wrote:sounds like the bike didn't know the clutch was engaged..... can't recall what electronic gubbins sense that.
check the clutch switch and wiring
Post by Beresford on Sat 27 Feb 2016, 7:20 pm
Spot on. I had a look and found one of the blade connectors on the clutch switch was loose. I pushed it on firmly and bike started right up when lever was pulled in.
Post by jerryfudd on Sat 27 Feb 2016, 7:24 pm
sweet, nice easy fix Smile
arrison
Post by arrison on Sun 28 Feb 2016, 7:46 pm
Ive found the spade connectors on the clutch switch are a touch on the large side for the connectors. Helps to squeeze them up a bit with a pair of pliers for a tighter fit.
    Current date/time is Fri 20 Apr 2018, 7:31 pm
